Mounting Swingarm Spools On An 86 VFR750F
21 posts Started 22 Oct 2019 Last recovered post 14 Nov 2019 Wayback Machine snapshot 12 Dec 2019
Now that I'm done with my previous restoration, it's time to dig into my 86 VFR750F.  Since it has no center stand and I have very little chance of finding one, I want to mount spools on the swingarm so I can use my Pit Bull.  If anyone here has suggestions on how to do it, please reply.  I don't know if the swingarm itself is thick enough to drill and tap, so maybe I need to machine a couple of threaded mounts to weld onto the bottom of each side?  Anyway, you know what I'm looking for, so feel free to chime in.  Pictures are always welcome.
Thanks.
metal is thin on swingarm, not ok for drilling or welding, so find a rear stand with flat plates that go under.
just run an alltread rod through the rear axle and add the bobbins to that..
2 hours ago, gll429
wha ?? that bloody axle isn't hollow like alot of modern bikes. 😒
[image: march_17_071.thumb.JPG.5f9dfeb51e1222354cd101720d6dc797.JPG]
The 86 rear axle is hollow.
https://www.ebay.com/itm/1986-Honda-VFR750F-Interceptor-Rear-Axle-86/281659679255?hash=item419439a217:g:hJ0AAOSwxYxUseqc
As gll429 mentioned above, run a rod through the axle. On my 85 R I used a solid rod, think it was 10mm and threaded one end then tapped my bobbin and screwed it on, Ran the rod through the axle, think I needed to ream a few imperfections, measured, cut and repeated the same one the other end.
On my 97 front axle I just tapped either end and used a flat head socket screw for attachment.
I have 4 paddock stands and they all have the both the spool and flat attachments, but the flats are nowhere as secure as the spools which is why I fitted them.
Good luck.
[image: DSCF3345.JPG]
[image: DSCF3342.JPG]
[image: DSCF3347.JPG]
This is probably a better picture.
[image: 512a5b9815eaf02bc5f48ad01e907f60 (1).jpg]
sorry, but i believe that both axles on MY '86 VFR's are not hollow but i may be wrong. 😒
2 hours ago, squirrelman
Rear is hollow enough to store nuts in.
2 minutes ago, Captain 80s
Rear is hollow enough to store nuts in,
OK, good for squirrels then
[image: 1529525782_052_52sweetya.thumb.JPG.e498fb28c3812801d38fcb2e5beeeb35.JPG]
FromMaine, ‎10‎/‎23‎/‎2019 at 4:48 PM
Good luck.
I love this approach - this is the route I'll take.  Thanks!
Maybe I missed something... How can you not weld a bung or spool onto the swingarm.  Unless you have no welding skills?  I've seen braced swingarms.  Here is a pic of my Honda RS 125 and that swingarm is thin!!!!  Just curious.....
[image: IMG_20191026_204537.jpg]
You didn't miss much.   Honda welded fairly thick tabs for the chain guard no problem too.  I have a swingarm from a parts lot I bought that the chain guard tab broke off in a crash and the weld and swingarm are still perfect.  The chain guard still had the tab held by the bolt and the chain guard is still good too somehow.
The only thing you missed was your aluminum polish.  Hah!  🙂
12 hours ago, Captain 80s
DAMN that phone camera!  That bike has been sitting on F/R stands on the work table in my living room.  Could use a bath
shamefully and humbly i'm admitting to the entire VFR universe, all 7 continents, and all the ships at sea that i was wrong, wrong, wrong. it does have hollow axles. SORRY ! 😮
i've only been working on  VFR's for 29 years but shoulda known better.
[image: oct_15---18_001.JPG]
The axle is hollow, but it tapers down to a smaller I.D. approx. .5" in from the threaded end.  (probably so that the end doesn't squish in when the nut is torqued?)  The threaded rod I used slipped through nicely until I reached that point, so I cut some threads in the very end to resolve that issue.  The spools are on, but unfortunately, my PitBull is not tall enough to life the wheel completely off the ground.  Not a big deal since this setup is only good for servicing the chain anyway.  I've ordered a different rear wheel stand that doesn't require spools and will allow for wheel removal.
16 hours ago, squirrelman
LMFAO!!   I'm coming over and you better have more beer!
2 hours ago, tomk1960
No offense, but if it only lifts it just enough to lube the chain and you have to buy another stand so you can remove the tire, than it sounds like a waste of time and effort.  A couple of welds below the swingarm and bam, your in business.  But hey I'm glad the axle is hollow.
squirrelman, 10/22/2019 at 8:40 PM
You do realize the factory welded it together, right?
I've welded beer cans together on a dare. No reason a competent welder couldn't add a threaded boss to a swingarm.
Rivnuts/Nutserts would be my go-to non welded option, although I've also machined lift hooks with custom axle blocks for them to bolt to. Both options are preferable to a through-axle mount, simply for the convenience of being able to remove the wheel while on the lift.
I'm pretty happy with my front and rear stand combination, the rear just lifts the swingarm using rubber pads on metal angles that can be adusted for width. And the front lifts directly on the steering head via a pin inserted into the stem. It's a fantastic combination until you want to remove the swingarm/shock or the steering head.
[image: IMG_0218.JPG]
^^^^ Your bike and shop are disturbingly clean. Beautiful VTR.
End of thread · 21 posts recovered Wayback Machine snapshot 12 Dec 2019
