Will a 2014 VFR800F Pannier fit my 2010 VFR1200F?
12 posts Started 9 Mar 2020 Last recovered post 19 May 2020 Wayback Machine snapshot 30 May 2020
Thanks a million
19 minutes ago, tomcatek
They will.
Should i anticipate any issues?
RasXB Should i anticipate any issues?
If your bike had no panners leaving the dealership, you might be missing this stabiliser. Without it there is a bit of wobble, but still panmers are still usable.[image: 05ea3881fcf424fea2bc574e5aade18a.jpg]
But beside that piece of rubber you're good.
[image: bb098b62d7dc86dc2c7a4eeb065652b4.jpg]
The rubber steps should come with the new panniers. If not and assuming they are the same as the 8gen here are the Honda part numbers.
08L02-MGE-D10      RUBBER STEP R
08L03-MGE-D10      RUBBER STEP L
Than
Grum, 3/9/2020 at 10:31 PM
Thanks a million, appreciate your help
Just now, RasXB
Than
I would provide update once the boxes arrive.
There is a heat shield on 1200f RHS pannier.. Whether it will be an issue I don't know.
Viffy There is a heat shield on 1200f RHS pannier.. Whether it will be an issue I don't know.
It won't. On 8th gen exhaust is on same side on similar height. If no tuning was applied you're in the safe.
The panniers eventually arrived, delayed due to COVID pandemic. They are [image: spacer.png][image: spacer.png]perfect fit, no issues so far. Yet to configure the keys though, if that works great too, that's a 100% fit. Thanks all for the help.
End of thread · 12 posts recovered Wayback Machine snapshot 30 May 2020
