4th Gen Adjustable rearsets Danmoto CBR900RR
1 posts Started 13 Aug 2020 Last recovered post 13 Aug 2020 Wayback Machine snapshot 23 May 2024
These are basically new. Never used just mounted. I bought them and they fit fine but at the highest level they were barely higher than stock foot position. I wanted more height so I ground some material from the bottom mounting holes of the footrest plate so I could angle them up and took some material off the gear lever near the swingarm to get clearance as well as 1/2" spacers at the frame. Once mounted you can't tell they've been massaged to fit that postion. They still have all the adjustability as the intended, just now a little more.
Comes with everything in the picture including the master cylinder which is also new. Will need the heim joint at the gear selector on the motor and 1/2" spacers (which can be purchased at you local hardware store for a few bucks) I also upgraded 4 bolts since the ones that came with them were cheap in my opinion.
$150 free shipping to US only.
Can provide more detailed pics once I get them off.
[image: IMG_5884.jpeg]
End of thread · 1 posts recovered Wayback Machine snapshot 23 May 2024
