Hi, can anyone please verify if the key code can be found under the gas cap?
I think I've lost my key...
edit - I should note, it's a 2010 VFR1200F
Look around cylinder where key inserts. Do you see word "HISS"?
I see nothing that'd indicate HISS:
[image: image.png.ff219a81f5773848bd7d61eea8ae2a71.png]
But I was finally able to pick the lock to the gas cap, and there is a three letter marking, I'm assuming that's the key code?
[image: image.thumb.png.53bb920e9113e94ed3bb4cf65bba7e64.png]
It's looking like I'll just need to get a locksmith to come out to cut a key.
Nevermind...
Not sure on this particular model, but gas-cap on many bikes have fewer tumblers. Not sure if that keycode cuts key for master that works with everything, or just gas-cap.
You can also go down to dealer with VIN and they'll cut you key as well.
Can’t tell you if that is the key code but I checked under my gas cap and my stamping is different. I didn’t find anything in service manual about key, but is huge and not searchable so low confidence...
Let us know if you find anything solid.
