I have a 1990 VFR that was in almost pristine condition. During a recent move, it slipped on the trailer and suffered some minor fairing damage - cosmetically, it is going to be fine, but it is no longer quite so immaculate. One of the issues is that the left middle fairing got "popped" out of place - essentially, the stress pulled the leading middle fairing attachment bolt through the fairing and it looks like the 1/4 turn fastener at the front of the middle fairing piece that joins it to the lower cowl/belly pan section essentially broke off/damaged the "tangs" that engage the fastener - at any rate, it will no longer engage. I've repaired the damage done to the middle fairing mounting hole, but can't seem to find the correct part number for the riveted on "clip" that engages the fastener. Does anyone know what part number or of a source. Best I can find, it would appear Honda only sold the lower cowl as an assembly and didn't have a separate number for the attachment plate.
I can use a "speed nut" type of fastener, but then the attaching bolts won't be "original" and won't match the other side - and I'd really rather try to keep the "vintage" appearance.
1990 Fairing Repair
If they're like my 4th gen, the 1/4 fasteners for the fairings were Dzus fasteners (the inventor's name). My airplane mechanic friends pronounce it "zeus" - not sure if that's correct. Anyway, they're readily available. A quick search turned up a vendor (I know nothing about them - just an example) - ebay, Amazon and others almost surely have them as well. You may have to buy more than you need. Since the part you need is hidden it shouldn't matter if it's not an exact match as long as the function matches. I wish Honda had continued using those vs the collar bolts and plastic pins they went to later. The Dzus fasteners gave it a high tech aviation vibe that were also a cinch to use. Just another example of how 3rd and 4th gens had such exceptional build quality. Good luck with the repairs.
https://southco.com/en_us_int/fasteners/emdzusemreg-quarter-turn-fasteners
That certainly does look like the fastener that's in place - but the "receptacle for this - and the others on the fairing pieces don't have the "wire" center piece for the fastener to engage. It appears that Honda is using a "speed nut" type of clip riveted to the lower cowl that only has two "tangs" that engage the fastener - and that is what I'm trying to track down. Failing that, I can replace it with a true metric "speed nut" and matching bolt - easily found - but then I lose the "original look."
So this is not (generally) the style of clip needed?
[image: Dzus.JPG]
There are numerous styles - possibly one of them here? Sorry - I haven't owned my 4th gen for over 20 years, so my memory of it is fuzzy.
https://southco.com/en_us_int/fasteners/emdzusemreg-quarter-turn-fasteners?receptacle_style=Clip-on
Yes - that is the generic style of clip. The Honda one is "pop riveted" in place but a clip style would work just as well. I'd not found this source in my search - Thank you!!
I’ve never seen those attachments sold as spares, presumably Honda bought by them by the ton or whoever made the plastics
Your best bet to stay 100% OEM is get a broken fairing piece
These look similar to the OEM style receptacle: https://www.speedyfasteners.com/Silver_Dzus_Fairing_Fastener_Stud_Kit_p/sf128.htm
No sure they're the same dimensions.
JZH
Very similar to that link! Thanks - I'll see if I can find them this side of the pond.
And, yes, it looks like Honda never carried them as a "spare" part. Except for this unfortunate situation, I've never had an issue with the fastner system so was hoping someone had a source. Looks like I will be chasing a "generic" replacement. At the worst, a "speed nut" and a button head bolt will make the attachment.
Thanks for all of the suggestions.
Besides the sources listed above from Cogswell and JZH, Kurvygirl might have what you're looking for. https://www.kurveygirl.com/shop/
I googled 'Honda style Dzus receptacle' and found this; https://www.ebay.com/itm/191959936702
[image: $_12.JPG]
Based on eBay pics of used panels it is more or less exactly what you need. The studs and plastic retainer washers are still available from Honda.
