Hi Rhoderage.
From what you're describing.
1. You've developed a Red wire (12v from main fuse A) to Yellow/Red wire short!
Check the Red connector at the Starter Relay.
2. It could also be an issue with Main Fuse A 30amp somehow shorting to the Yellow/Red wire terminal.
3. Or it could be an internal fault/short inside the Starter relay to the coil positive side.
The bottom line is your Yellow/Red wire has permanent 12v attached to it, so the Positive side of the Relay Coil is permanently seeing 12v! (Refer to the drawing Terry attached.)
Having this situation will mean the Starter Relay will energise Any time you're in Neutral, OR in gear with the Sidestand Up, and you pull the Clutch In. Even with Ignition to OFF........A nasty situation!
If the Relay had jammed closed in the energised state, or its main contacts had welded together, then you'd never stop the starter motor from running unless the battery was disconnected or you're starter motor burnt out, or your battery dies, or it goes up in smoke!!! Fortunately, you don't have that situation.
Closely inspect the relay and its wiring. If the wiring is good then replace the relay as it must have an internal short issue.
Here's some Electrical checks you could do.
1. Bike on Center Stand, lower the Sidestand and put the bike In Gear. (this isolates the Ground side for the Starter Relay coil via the Green/Red wire for safety).
2. Remove the connector from the Starter Relay taking note of which terminal the Yellow/Red wire goes to.
3. See if you can clip your voltmeter Black lead to the battery negative terminal.
4. Ignition Switch OFF. Reconnect your Battery.
5. With your Red meter lead, probe the starter relay terminal where the Yellow/Red wire would go to. Normally, you must NOT see 12v at this terminal. If you do, then the short is internal of the starter relay. Replace the Starter Relay.
6. If step 5 is ok. Check for shorts between the Red wire and the Yellow/Red wire. Ignition Switch to ON, Kill Switch to Run and with your meter on the lowest Ohms range. Place a probe on each of these wires with the connector still disconnected from the relay. Make sure you have No continuity between these two wires. If you do have continuity (low ohms reading) then the wiring is at fault. You should ONLY have continuity when you press the Starter Switch.
Hopefully your Starter Motor has survived the ordeal!
Let's know how you get on.
Good luck. :fing02:
[image: image2(2).JPG]
[image: image1(1).JPG]
