14 hours ago, Cogswell
Sorry for your troubles. :sad: Someone had that happen to a 7th gen IIRC in Africa? some years ago, maybe 7 to 8 - anyway, he got another motor and swapped it. IIRC the bearings in that motor were ruined. Motors are around, but you have a DCT, that might be more difficult to source. For your location, the expensive part of that would be shipping if it were coming from the US particularly, or even from the UK or other parts of Europe. At this point you're on the right track - you might before pulling the motor out, drain the oil and have a sample analyzed - and then run a magnet through the oil to see if it picks anything up. Also, cut the oil filter open and see what's inside. If there are magnetic particles in it, she's had it. Probably a given if the engine is seized. You could pull the pan and then remove a rod cap to inspect a bearing if you want to see that prior to dropping the motor out. Hopefully you can source another motor and get her back on the road - it's a nice looking bike in that color.
Best of luck with it.
I've drain the oil splashing on a top of a magnet and discover nothing. Cut the oil filter carefully still nothing then I discover why there was nothing after I pull the pan off. The chunks of shiny/gold color metal were so large the oil funnel filter them and they stay in the pan, draining the oil wouldn move them out as they big and heavy!!Just imagine.... The mesh filter is microscopic to let any metal particulates through to end up in the filter.
Unfortunately the main/rod caps are high up in the engine and cannot even see them. Further disassembly required. Spend the afternoon fighting single engine mount bolt seized hard (UK kinda rusty bike) Got it out and gave up for now.
Oil samples are not available arround and kinda pointless at this stage , but thank you for your companionship. Really appreciat fine suggestions!
12 hours ago, rhoderage
One of my coworkers bought the first 2010 released in Canada, pre ordered and paid for. Waited a year for it. Was so excited - at less than 10k km, engine grenaded. I don't remember exactly but bearings were involved. Honda refused to cover it, he literally parted the bike and lost the better part of $20k Canadian.
Its the main reason I haven't tried to buy one - way way more examples that have no issues than do have the engine issue, but your experience is super unfortunate and one I'd rather avoid.
I believe the problem was more common across the pond... may have been a Honda recall? Swarf left in the engine at manufacturing
That was horrible10k and engine failure! I thought swarf problem was only on the european models (doesnt make sense since all are made in one line in Japan) But yeah , I've got the impression that when new even for the ''west" people that was an expensive bike, and this to happen , and Honda not to take responsibility is bad bad bad. Honda admited for the swarf left from manufacturing but only for 397 bike in the UK and recall them all. Or at least that what old artical I found says. But Honda UK is another story, they use to fix granaded out of warranty spayed with 50shot of nitro engines just to make customers happy (another story I've read). Anyway...
Will fight for now but I see only used engine as an option, and then what? Swarf blocked oil passage will may still be there.. I'll be so affraid to push it and whats the point of having 1200 if you ride it with 250 speeds.. I dont know...
1 hour ago, Thumbs
Not sure if there’s much difference between the VFR and the Crosstourer but here’s a complete motor and automatic gearbox
https://www.ebay.co.uk/itm/274857159943?fits=UKM_CCM%3A1200|UKM_Make%3AHonda|UKM_Model%3AVFR&hash=item3ffec36d07:g:TWAAAOSwmwtg4yOn
Cant see many difference just looking at it, but sure there is and 2k is a bit steep for me
1 hour ago, Sunde
What a fucking mess
Was one of my worst fears picking up this bike, the stories of the engine just dying of death with little warning.
Mind if i ask what generation your bike was? I am yet to hear of a 2011+ gen having this issue.
Yes, yes it is...
I granaded an old Honda Civic 1.3 the same way only it ran for thousands of km with the oil pressure warning light slightly flashing before it locked up(kinda didnt care about that car,and afterwards got a good used engine for 40euro and swap it for 3 hours). Here I only saw oil light 5 seconds before it blew. And I was parked, what will be if it lock with 200kph?
Mine is '11 UK bike
Comming in the right moment after I've spend all my savings on this bike and a new car (present for my old man)
Thank god I have a good friend who drove for hours with his van to pick me up 3 o'clock in the morning...
