I removed the front sprocket cover, and now my clutch lever is impossible to pull in. Also the pin into the slave cylinder seems to be out too far. Is that the lifter? I am new at this but learning through the forums so any help is appreciated. This is a 2007 RWB Anniversary nonABS. Air in the line? I am 3rd owner and just turned 50K so thinking I should bleed and replace parts anyway, but if there are any other possible causes, help is again appreciated!
Clutch lever not moving after sprockets and chain replacement
3 posts Started 14 Oct 2021 Last recovered post 14 Oct 2021 Wayback Machine snapshot 27 Nov 2021
When you removed the sprocket cover did you clamp the clutch slave cylinder to stop it coming out too far? If not then it may be beyond its normal operation range you may have to remove it and the reseat it.
4 hours ago, RRluv2RIDEAlso the pin into the slave cylinder seems to be out too far. Is that the lifter?
Yes, so it may not be fully seated into the pressure plate.
End of thread · 3 posts recovered Wayback Machine snapshot 27 Nov 2021
