Lifting to centerstand
39 posts Started 26 Jun 2022 Last recovered post 2 Jul 2022 Wayback Machine snapshot 18 Aug 2022
I did search for this topic but I guess I'm the only dumb one that is asking this. Okay, you have to admit the Gen 6 is a heavy motorcycle, right? I'm always afraid to lift it to the centerstand for fear it will get away from me and fall away from me to the right side. Is there a technique that you guys have a handle on that may give me more confidence in lifting this motorcycle to the centerstand without it getting away from me? Any suggestions on this subject would be great. I know you guys are gonna say lift more weights 🤣.
I'm a weakling and getting much heavier bikes on the centerstand takes some practice. I start on the side stand, find a place to firmy grasp the bike (Givi mounts or grab rails) so I can pull it back to the sidestand if need be, push the centerstand to touch the ground while getting bike bike upright. You can feel when both side of the CS touch down, then just push down with that foot and pull back with the firm grasp. So easy a caveman could do it.
My FJ was a beast...much heavier than the VFR.
[image: IMG_0731.thumb.JPG.b0be12c4b8515868d2dbcf430ecd0f0a.JPG]
Once the stand is in contact with the ground and you have a little weight on it, the bike will be as stable as can be. Then it is a matter of pressing down on the stand and lifting/up and back on the frame; I use the edge of the pillion rest as a point to lift on.
The force needed will vary with how far you need to lift the bike  and it can help to roll the back wheel onto say a bit of plywood; that reduces the lift height and makes it easier. If you have lowered suspension or the stand is on a higher point of ground, the job is tougher.
18 minutes ago, Terry
I've sure given some thought to rolling the back wheel onto a small piece of plywood (3/4 thick maybe) or something to assist me in lifting it. I have a rear seat cowl so that makes it difficult to hold on in that area. Really I don't find much of anything to hold on to for lifting. Unless I remove the luggage cases. Makes me remove the rear cases every time I would like to lift the rear for chain maintenance. I guess if that's what needs to happen in order for me to keep it from falling away from me.
As Bmart explained, you do not lift, you pull it back while holding the center stand with you foot to the ground.
By the way Bmart, Cavemen were much stronger than we are, lol!
4 hours ago, Kbear
Good advice so far, but your reply is vague as to where you hold onto the VFR. I hold the left handlebar with my left hand, foot on the centrestand, and right hand palm-out holding the passenger peg/pannier bracket as indicated below.
So long as the ground is level your VFR should be quite stable while you lift. As the others note, press down and lift at the same time.
One thing I did that made the job much easier was a good clean and lube on the pivot of the centerstand. My 93 is much older than yours, but mine went from difficult to get on the stand to easy and it didn't look that bad when I took it apart.
2 hours ago, Kbear
With panniers on I imagine you can't get to the handy rail that Lorne highlighted, so maybe you do need to remove the left bag.
My ST1300 weighs a LOT but does come with a fold-out handle for hoisting onto the centerstand. I make things worse for myself (but good for my Mancave floor) by having plywood under the stand, so I get to lift the bike even higher that standard. Without the handle, that would be a no-show.
Not a dumb question at all. We all struggle with this until someone shows us how to do it.
All good advice given so far. To reiterate what's already been said - the most important thing is that you shouldn't aim to be "lifting" the bike, I've hurt myself trying to do that on various bikes before I worked that out - the key is to roll the bike and use its momentum to get it onto the stand whilst anchoring the stand with your foot - it's a bit of a dance but you get the hang of it.
I've got better at it, but I still don't enjoy putting the bike on the centre stand. I understand your fear of dropping it. With the sidestand down it's not doing to fall that side - if you do it with a wall on the other side and something to protect the bar end on that side whilst you're practicing,  it's not going to fall far that side and damage anything if you do drop it.
Lots of how to videos on YouTube of not particularly big or strong people putting bigger bikes that these on centre stands.
11 hours ago, Terry
Shoes matter here, FYI, I've seen folks try our method with s%$t shoes or flip flops and you can imagine what happens next...
10 hours ago, Wald
A shame we'll never meet a full blooded neanderthal. Those dudes look stout!
[image: file-20190130-108351-1btg7w0.jpg?ixlib=rb-1.1.0&q=45&auto=format&w=754&fit=clip]
And if you have a human who can help, have them do the lifting from under the luggage while you use your foot on the lever. Once you sort out the mechanics and direction of effort, it is pretty easy.
I'll absolutely agree with what's been said: your issue is right in the title: LIFTING TO CENTERSTAND. You don't lift, that's an easy way to a bad back
or hernia. 🙂 When you get the centerstand legs on the ground, both of them, concentrate on pushing the centerstand into the ground, use the
bike for leverage to help in pushing down. Don't consciously lift up, just press down, done right, the bike will all but leap onto the centerstand. Of
course this is all a lot tougher if the bike has been lowered.
Magical. I'll have to try that one! I think he has ~200# on me...
18 minutes ago, bmart
I wonder if that boat still floats with him on board ?!
Americans have gotten...impressive in size. Part of why I don't fly anywhere is that I got tired of having to give up one or both halves of my seat.
17 hours ago, Kbear
Absolutely no such thing as a dumb question. Most of us on this forum are happy to help if we can, and forum searches don't always work too good.
No, you do not have to lift weights because centrestand technique is precisely that - a technique.
I have a 5th gen so I do not know exactly where your lifting handle is.
I started riding in the seventies and came back to riding after a decades long hiatus. The first thing that I noticed is that there is too much fashion over function with many modern bikes and I was nervous when using the centrestand despite having heavier bikes in the past. The modern centrestands do not seem to be not as wide as my old CB750 and GS1000E stands ( I could be wrong here as it was a long time ago), and that gives you that 'nervous' feeling when you first bring the stand down.
The most important thing is to have the right hand foot of the stand touch the ground before you start lifting the bike. Have a friend stand on the other side to give you confidence in case you feel that the bike is going to topple. At this point the bike should feel very stable. Now reduce the weight on your left foot while holding the lifting handle and put all your weight on your right foot on the stand. If you are a heavy person the bike will almost go back on its own as it pivots on the stand. Do not pull on the handlebars. Your left hand is there only to keep the bars straight. As you apply all your bodyweight to you right foot, pull back on the lifting handle while the bike pivots on the stand and moves backwards with momentum. It is just a light guiding pull, not a Herculean one.
To get the bike off the stand I straddle it and push or rock it as I am tall.
If you do this a dozen times with a friend on the opposite side you will learn the technique pretty fast.
It goes without saying that you have to be on level ground to use the centrestand.
Sorry that this is so long winded but without showing you in person the explanation is long.
A few videos to help you out' The last video is Max from Traxxion Dynamics suspension...... a Goldwing. Observe how wide the stand is on that bike. That's what makes it very stable. That's what I was referring to in my opening comments. My CBR1100XX has the worst centrestand that I have ever seen....very narrow, on a top heavy bike, yet the lady in the second video has no problem lifting it. It's all about the pivoting technique.
One of my favourite youtube channels, and there are tons of other videos on you tube showing you how to put a heavy bike on the centrestand.
Hope this helps
[video: https://www.youtube-nocookie.com/embed/t6TGuO03wHM?feature=oembed] [video: https://www.youtube-nocookie.com/embed/KuOSOzb3zGw?feature=oembed] [video: https://www.youtube-nocookie.com/embed/w3kaUgoJshc?feature=oembed] [video: https://www.youtube-nocookie.com/embed/YBXhlK604Vw?feature=oembed]
Awesome guys!!!! All the great advice is super. I have a couple other motorcycles with centerstands that are not of any issues, but for some odd reason this 2007 VFR800 seems a bit awkward lifting to that stand for me. Maybe it's because I'm afraid of having it get away from me and fall on the right side while I'm placing it on the stand. I need far more practice then I originally thought. I have placed it on the centerstand before (without panniers) but yet I didn't feel comfortable doing so hence the asking if there was something I was missing. Everything you Gentlemen have suggested is fantastic and I will try them all until I can feel more confident with placing this motorcycle on the stand.
Been practicing "rolling" the VFR on to the centerstand. For me anyway this is a heavy motor. I wanted to make sure I can lift, roll, on to the stand with the panniers on. It can depend on where I place my right foot on the lift peddle as to how well it will work. If I place my foot on the ball there's a balance issue so I end up putting more of the arch of my foot on that peddle, just behind the ball of my foot. Also you need to have somewhat stiff soles on your shoes. My PUMA tennis shoes where not having it. As Lorne said to use the pannier bracket I did. At first I didn't think I had access to that bracket with the panniers on but I do. This makes it much easier to roll back while lifting at the same time as well as pushing down on the lift peddle. Still this is a heavy motorcycle and as I push the lift peddle to the concrete floor I get this uneasy feeling that it wants to fall away from me to the right. I know I'm just being a puss and I need to get over it. I will, I just need to place it on the centerstand more often. Thanks, again, everyone for the great responses to my naive centerstand lifting issues! 😎👍
[image: 20220629_092355.thumb.jpg.82d0b78c47508c50c88661a372d25fc0.jpg]
Try left foot, so your body isn't twisted.
43 minutes ago, Kbear
You have probably heard the joke about how you get to Carnegie Hall.  Practice! Practice! Practice!
I have a few tips to go along with what everyone else said.
Use the ball of your foot.  You have more power there.  Wear boots.  I use my passenger footpeg bracket for my hand to grip.  I use my knee against the bike for stability til both legs of the center stand touch the ground.  Then I put all my weight on the center stand while pulling up on the footpeg bracket with my right hand, and pull backwards on the handlebar with my left hand.  I have used a board under the rear tire, it does help, but I don't anymore.
My goldwing buddy just uses reverse to get on his center stand.  I hate that!
To get off, put the bike in gear so it doesn't roll away.  Put the side stand down.   Rock forward and keep it balanced.  Good luck.  It gets easier with practice.
43 minutes ago, bmart
For me anyway. If I were to use my left foot I would be twisted around.
Btw, there no shame in asking someone else to stand on the other side of the bike and spot you til you feel comfortable doing it by yourself.
Maybe you practice on bikes at your local dealer. 😛
2 hours ago, Kbear
My ballroom dance partner is constantly telling me that I have two left feet, so using my left foot to lift the bike is a no-brainer for me 🤪
I find the VFR a challenge to get onto the centre stand too. I'm medium height and slim build, but unfortunately not one of those people that's really skinny yet unnaturally strong!
My technique is to turn the bars fully left, grab the left bar with my left hand, grab the rear passenger grab handle with my right hand and pull the bike backwards with as much downward force as possible on the centre stand using my foot. As others have said it's definitely easier with proper boots on. If I've moved the bike to clean it and have got my Nike's on, it's a struggle.
Using that piece on the pillion footpeg looked like a great idea but when I tried it, it was too low for me and hurt my back.
3 hours ago, Dorian
True. I found the passenger peg a bit too low for me as well to get a proper hold and lift as I'm pushing down with my foot.
21 hours ago, Dorian
I tried your technique of turning the handlebars fully to the left and pulling on that bar as you lift with your righthand on the rear pannier bracket while pushing down on the center stand peddle today. Worked GREAT! Yes, I know that every video will tell you NOT to turn the front wheel in any direction, but I'm telling you it felt much better for me to do than leaving the front wheel straight and not using that handlebar as some sort of leverage. I will definitely be turning the handlebars to the left and using that bars side to help pull the bike backwards and onto the stand!!!! Thank you so much for the advice on using that technique. A real confidence booster.
BlackheathMatt, 6/27/2022 at 4:26 AM
You summed it up in one statement. Everything else in your post is also very good advice. 👍
As long as people keep on thinking about PULL and LIFT, they will never get it (unless built like the guy in the video that I posted 😄).  Once you get the technique it's just a smooth "roll" with the centrestand as the pivot.
3 hours ago, RossR
Wot he said.
44 minutes ago, Skids
Wot he said.
Click the little black arrow on the right hand side of the Quote and it will take you to "Wot he said".
27 minutes ago, RossR
I think Sir doth misunderstand.
I was agreeing with you m8. 👍
30 minutes ago, Skids
Ah! Ha! Good Sir! I have been educated! Some more good Blighty slang to add to my lexicon when I next cross the Pond to mingle with my South London mates. 😃
2 hours ago, RossR
Surely you mean Sarf Larndon?  :goofy:
Do you visit regularly?
1 hour ago, Skids
Yea! Yea! Mite!
Used to visit annually. Not so much now.
I turn the front wheel all the way to the left. With left hand on left bar & right hand on left grab handle & right foot on center stand, I then pull back with both hands & it lifts right up.
it's been mentioned already, but wear boots or hard soles or you could hurt your foot.
End of thread · 39 posts recovered Wayback Machine snapshot 18 Aug 2022
