O2 Eliminators
4 posts Started 26 Feb 2005 Last recovered post 26 Mar 2005 Wayback Machine snapshot 26 Apr 2005
can anyrider direct me to a website for O2 Elims on an '03 VFR? Thanx 4 the help!
DynoJet, the same people who make the Power Commander or any shop that sells these products can order them for you ! :)
What an O2 eliminator does ecxactly ? I mean , is there a power difference, what good can come outta installing an O2 eliminator ?
Halfasleep, Mar 26 2005, 07:05 AMWhat an O2 eliminator does ecxactly ? I mean , is there a power difference, what good can come outta installing an O2 eliminator ?
the o2 elim has two uses....first, if you are going to install a powercommander to tune fuel injection settings you will need them.
2nd....the only other way you will want them is if you feel a "lag" while you maintain a cruise rpm. you will be cruising at around 4500 rpm or so and you may feel the o2's lean the mixture excessively and the bike feels like the power ended . some bikes do it, some worse than others, some dont do it at all or not noticeable enough for their riders to feel it. mine did it mildly and i went the o2 elim route. it cured any issues i had with the bikes operation
End of thread · 4 posts recovered Wayback Machine snapshot 26 Apr 2005
