DAM, The MBD Strikes Again
12 posts Started 7 Oct 2022 Last recovered post 26 Nov 2022 Wayback Machine snapshot 2 Dec 2022
1 hour ago, squirrelman
allballs is cheap chinese commie trash maybe ok for head bearings, not for wheel bearings !
Great comment.  Luckily we weren't talking about wheel bearings at all.
What kind of oil do you run?
You think it's ok to pop a dust seal on a Japanese wheel bearing and add some grease?
The problem with AllBalls is that they don't make bearings.  All they do is buy bearings from the "most economical" source and package them for retail.
You could do the same thing, pay less and get higher quality bearings.  Your choice...
JZH
For many people in a steering head bearing application, the product meets their quality and price point target and is readily available from multiple sources.
Industry leaders like Timken source materials from all over - including China.
Somewhat relevant - wheel RPM and load is less than we think so you rarely see very high end or exotic bearing types or materials in hubs.
If you’re in the states and are particular about your bearings, Dubya USA stocks Japanese bearings that are supplied by a Japanese bearing importer across the street from them.
Captain 80s, 10/7/2022 at 10:23 PM
The same reason many people buy standard parts (like bearings, which Honda doesn't manufacture) from Honda.  However, there isn't the same concern over quality...
JZH
Well guys the Yellow bee finally made it home to the east coast, I must say I can see why guys with bikes from the west or dry parts of the country are always talking about their clean bikes
So far I can find very little rust or corrosion, amazing considering what I am use to seeing on a twenty year old bike from the east coast 30 miles from the Atlantic
I have started the list of service work needed, and as I thought ( at 30,000 miles ) I can see front wheel bearings, fork seals, steering stem bearings, etc, as well as new plugs, filters and a valve check with injector syn. etc
Question#1, I will ask can the front forks can be easily removed from the bike with the rear end strapped down to the floor,?
Or do I need to build a block and jack system under the engine ?
Question#2, The bike arrived with brand new skins on her and I was wondering if most of you guys have them balanced on a bubble balancer or go to a motorcycle dealer or tire shop with the proper adaptor for the rear wheel?
5 hours ago, Hingley
That will work.
My "garage" is the front garden, so I used a jack under the engine. I bought an ABBA stand since.
As Dutchy says, easy to do. I use a car jack with a small piece of wood on top then support the bike with it under the exhaust pipes.
You can rest the bike on the downpipes without damaging them.  With the bike on the center stand, I mean.
You can certainly achieve a very good balance with a manual stand of some kind--there is no benefit to spin balancers apart from speed.  That said, usually only the front wheel is very sensitive to balance.  I've run the rear without weights at all, back when I didn't have an adapter.  (You can make a simple adapter using shcedule 40 PVC pipe fittings.)
JZH
I was really wondering of the pipes under the motor can stand to have a support block on them for a period of time, good to know before I started cursing
if they can not stand the pressure
I am surprised that the Rear works ok without balancing, considering the single sided arm etc
I figured the front will pay off with a balancing, I will have to see if I can find a good bubble stand
Wish I had her serviced already, it should be about 32 degrees F and snow in the air but it is sunny and 70 degrees, strange fall, we are going to pay for this some day
Thanks Guys
Finally after dealing with hurricane Fiona damage and getting ready for winter here I have found time to put the 1999 restore project in its winter home.
[image: IMG_4051.thumb.JPG.2b31765f1bf44ece65f53041038a23d7.JPG]
Looks like I have some extra work to do as well, I had a quick look at the stator wires etc. and noticed they were dam warm on the final warm up for a winter oil/filter change.
I pulled the connectors apart and I would say there is signs of heat damage.
[image: IMG_3999.thumb.JPG.fd7cdaa97965bffd145b084541a992b4.JPG]
[image: IMG_4002.thumb.JPG.15181d96a540960f7509f3f0d03ca2fb.JPG]
And lastly I came across something I have heard of many times but nothing seen, a mouse nest on top of the air filter, I have to surmise that this nest was in the air box out west and hitched a ride here The little bugger was even chewing on the inside of the air box
[image: IMG_4056.thumb.JPG.073c6bcaa6fb5a9d8876a58e1f7faaba.JPG]
End of thread · 12 posts recovered Wayback Machine snapshot 2 Dec 2022
