Hi Guys,
first post after lurking on here for a while, and some admin help to get my account up and running.
I've been riding for about 18 years, and love streetfighters.My last one was an 88 model GSXR 711. In 2009, i broke it and myself quite spectacularly. After as few bikes in between, i ended up with a drz 400 SM top commute on, and a 2000 VFR8 as a project. It was bought from a dealer as a complete and fully running bike. I'll let teh pics do the talking for a bit.
[image: vfr800with1098wheel.jpg]
[image: vfrtlrradandnewbarsandrisers.jpg]
So far the bike as it stands has:
04 gsxr forks and yokes and calipers, with ducati 848 front wheel, 01 GSXR 1000 rotors, and a ninja 250 front guard
Ducati 1098s forged rear wheel, basically vfr arm, ducati hub/eccentric/caliper/brake rotor/sprocket, just a shim and a spacer to centre the wheel
ninja 250 seat and subframe
driven supercross bars, acewell dash, acerbis headlight
I ran it like this for the last year or so.
And recently
sp1 oil cooler and TL100R top rad as a front mount. The oil cooler is perfect, the front mount rad is almost perfect, just a few minor leak that thread locker and new crush washers should fix.
I do have a question though, does the air bleed hose that usually connects to the right hand rad need to be plumbed into teh system? or can i use it to bleed the air, and then block it up with a bolt and worm clip?
Looking forward to being a part of teh forum, and passing on what i have learnt about vfrs along the way.
