I have a stator question. I already had to once change my OEM stator for a Rick's one. It did fine for about 5k miles, then I did "The Drill" (voltage at 5k rpm was 13.6 when bike would heat up above 200 degrees) Everything was good, but I did notice that during the AC voltage test, the numbers would be pretty weak compared to the rpms. For example, a healthy stator would show about 20 volts at idle, and 60 at 5k. Mine showed a bit above 10v at idle, and 45v at 5k. It took me to get to 6500rpm to show over 50v. Anyway, am I just stuck ordering Rick's stator and having to do this over and over? I know I can also get it rewound, but are there any other options? I know that a 99/00 stator fits a 98 (my year 5th gen) but they seem to all be out of stock. Do 6th gen stators fit? or they just bigger in size? should I get a second hand OEM stator?
I need something for when this thing starts to fail... Thank you all!
Southern Rewinding have a great reputation and is probably the way to go. I can’t say there’s any aftermarket stator I’d trust, at this point. Everything is offshore garbage, made for a brand or rebranded to be a brand. It’s not good.
Someone could probably authoritatively answer this, but I think an 03+ 6th gen stator and flywheel would go on a 5th gen? Mentioning because I just bought a new Honda 03+ stator and a used eBay flywheel for my 2002. It's the $300 route but I too would like to do this only once...
You’re correct. They do.
For others, you DO NOT want an ‘02 setup, as they’re the smallest of all the years and are 1yr-only.
So youre saying, all I need is an 03 flywheel and stator, and Ill be good to go? if so...I think Ill be going that route. My question is...how hard is the fly wheel change? never done that before..
Lastly, you’ll want to add a voltmeter to your bike, so you can constantly monitor what’s going on with your charging system.
Hey! you think if I buy a new ricks stator and send it over there, they will rewrite it? I say this, casue I rather send in a new one, and ride out the one I have now, without going in there too many times. and about the R/R, I am running a Roadstercycle FH020AA, and I also have the SH847 as back up. I like to be super prepared.
Yup! Not too hard, there are some guides and videos. There's a special tool you can buy from ProMotion on Amazon, and you need a strap wrench.
I wouldn’t go through all that. If anything, buy a new Rick’s and install it. Send the one you’re running to them. If you can find an OEM stator that’s smoked, grab it and send that one. They only need the stator frame.
You need to run you R/R’s opposite; install the SH847 and keep the FH020 as a spare. The SH847 is a Series R/R and is the one that’ll help the longevity of your stator.
10 hours ago, VicSev93
So what I ended up doing is ordering a used OEM gen 5 stator off of ebay, and will be sending it off to southernrewinding for an overhaul, should be a good time!
Let us know how it works out.
End of thread · 13 posts recoveredWayback Machine snapshot 2 Dec 2022
