#1 Thread starter
I've tried to look through the forums as extensively as possible to answer two questions I have about installing my sweet new Laser system. I've come up empty and am hoping that the VFR Collective can help...
1. They come with a note that says the entire exhaust should be degreased with "white spirit" before the engine is started. What is "white spirit"? Is it turpentine? And should I get it all installed then degrease it or should I degrease it all then install it?
2. Have any of you folks that have installed your own Laser system used the "street legal" inserts? Are they too quiet? It seems that folks are mostly using the louder "Sport" inserts and, while I want more/better sound than stock, I don't want it deafening or obnoxiously loud.
While the inserts don't look like TOO much of a PITA to change, it still involves removing the slipons and I'd rather get it right the first time.
Any input is greatly appreciated!
Best,
Rob
Best,
Rob
