ABS LIGHT
2 posts Started 18 Sep 2023 Last recovered post 19 Sep 2023 Wayback Machine snapshot 8 Dec 2023
Hi people just got my VFR 800 2002 back up and running with a good bit of work done on it but can’t get the ABS light off. New sensor put in. Any suggestions?
7 hours ago, Padraig
Not much detail in your fault description!
- Are your tire pressures correct?
- ABS is sensitive to battery status, is your battery and charging system good?
- Are you saying that the ABS light remains On once bike speed is above 6mph?
- Any physical damage to either of the Pulser Rings?
- Are all four ABS fuses good?
- Have you gone through the Service Manual for fault code checking?
- Could the "work done" have effected ABS wiring and connections?
- Was the issue there prior to work done?
- What new sensor? Front or Rear? Did it have a fault code for the sensor?
- Are the Sensor to Pulser Ring air gaps correct?
- Have you checked all the ABS connections and connectors are clean and making good contact?
End of thread · 2 posts recovered Wayback Machine snapshot 8 Dec 2023
