USB port
20 posts Started 26 Sep 2023 Last recovered post 1 Oct 2023 Wayback Machine snapshot 17 Mar 2025
Hi, I am hoping to purchase a 2021 VFR 800F H next month & I will immediately be going on a mini tour & hope to fit a Quadlock system with charging device.
so now to my question, I can see it has a USB port on the left hand side but dont know if it has an actual USB port, how many ports or is a car type cigar lighter port?
googling for an answer simply shows me lots of people that have fitted after market USB ports on older models of the VFR.
OEM is no USB
Theres a plug in power supply under the seat that I run my heated jacket through if you’re looking for an instant solution
As you have a tour in mind I’d consider a new battery if it still has the original
Interesting, there is definitely a panel on the top of the left side panel that says 12V, I just do t know what is underneath…
Have you looked at the parts diagram?
Where can I find that?
So, you are going to buy a VFR800X Crossrunner?
 No it’s  a 21 plate VFR 800F-H model.
The only mention of a 12V 3A power socket I can find is on the X (2018+).  Have you seen this F in person?  Maybe somebody retrofitted one from the X.  I believe it is a cigarette style socket, as I read mention of somebody trying to use a mini air compressor and blowing the fuse.
I haven’t seen it in Person as yet but the pictures clearly show the  flap shown in the picture and the description of the bike says includes a 12V power socket.
it looks standard but as you say it might be a part from the cross runner as I can’t find it listed anywhere either.
i will know for sure in a few days….
The 2018+ X definitely has a power supply on the top of the lhs fairing. It's a cigarette lighter socket, not a usb.
No idea about the f-model.
Here you go. This is the 8th Gen F-H model: it's a standard 12v socket. Actually not great for wet weather unless you can find some way to weatherproof the adaptor
Cool!  Not the best location for constant use, but could be nice for a charge while at a stop.
Which I suppose isn't really nice cuz the bike's not on.
All Fs after 2016 had them. The explanation in the handbook doesn’t inspire confidence (attached). My Quadlock is wired directly to the battery.
5 hours ago, Presson
[image: 16957645678878986006450481807293.jpg]
[image: 16957645937793238224140273891492.jpg]
I mean, who doesn't need to light their ciggies while riding down the road?
10 hours ago, VFR78
[image: IMG_2068.jpeg]
Yes, basically don’t use in the uk as it ‘might’ rain…
10 hours ago, VFR78
Thank you, I think I will link the quad lock direct to the battery too when I get it home.
If you meed a power tap & just for a phone then you can tap the cooling fan supply. Been running my 5th gen from there forever. Just use a inline fuse on the wire by the tap.
Thank you, good tip.
10 hours ago, weewards
That's bollox, I use mine all the time through the worst English winter weather.
Mind you, on the X, it's on a more vertical face than the F.
I have ended up ordering the Denali Power hub 2 as I expect to have a few accessories on the bike and got a good price.
For what its worth the price quoted on sportsbikeshop.co.uk was £185.99 but discounted to £149 with free delivery, however I found it on  mandp.co.uk for £109 also with free post, sportsbikeshop.co.uk will do a competitor price match also if you prefer to order from them
End of thread · 20 posts recovered Wayback Machine snapshot 17 Mar 2025
