VFR Discussion Group -> VFR 95-97 Jet Choice
3 posts Started 9 Apr 2005 Last recovered post 10 Apr 2005 Wayback Machine snapshot 28 Apr 2005
Hey everyone, first i would like to say hello as i am new to the board :beer: Secondly i have a question. I have a two brothers full left exit (low) system on my bike with the C4 style can. Otherwise my bike is completely Stock. I get a horrible flat spot at Constant throttle, usually around 5-6k RPMs. The stock main jetting was supposed to be 125 front 128 rear. Upon removal i found 125s on all corners. I bounced up to 128s then to 130s. Something still just isn't quite right. The bike is in good tune otherwise, clean air filter, new plugs, Carbs synced, etc. Is there anyone on the forum who had a similar setup, and has this figured out? (The correct Main jet sizes for this application?) I really don't want to purchase one of two brothers "fine jet kits" for the hundred dollars; but if i can not find an answer i may need to....
Thanks in advance!
:wheel:
jloshotz, Apr 9 2005, 11:50 PMHey everyone, first i would like to say hello as i am new to the board    :beer:    Secondly i have a question. I have a two brothers full left exit (low) system on my bike with the C4 style can. Otherwise my bike is completely Stock. I get a horrible flat spot at Constant throttle, usually around 5-6k RPMs. The stock main jetting was supposed to be 125 front 128 rear. Upon removal i found 125s on all corners. I bounced up to 128s then to 130s. Something still just isn't quite right. The bike is in good tune otherwise, clean air filter, new plugs, Carbs synced, etc. Is there anyone on the forum who had a similar setup, and has this figured out? (The correct Main jet sizes for this application?) I really don't want to purchase one of two brothers "fine jet kits" for the hundred dollars; but if i can not find an answer i may need to....
Thanks in advance!
:wheel:
I think you should sell me your pipe and take my stocker...It will be nice and smooth and linear and you won't have to worry about it!
(I am actually looking for 2 bros, if you know anyone...)
jonda, Apr 9 2005, 08:40 PMI think you should sell me your pipe and take my stocker...It will be nice and smooth and linear and you won't have to worry about it!
jonda,
Yeha i actually scored my system CHEAP off of e-bay. At that point they were even still available throught 2 brothers. 2 Brothers has since discontinued the full system for our bikes and only sells slip on cans for our 94-97s.... :pissed: I'll keep an ear out for ya
P.S. i'll deal with the stumble; thanks for the offer :P
End of thread · 3 posts recovered Wayback Machine snapshot 28 Apr 2005
