VFR Discussion Group -> fuel injection light
4 posts Started 10 Apr 2005 Last recovered post 11 Apr 2005 Wayback Machine snapshot 25 Apr 2005
when i went through a short rainstorm my fuel injection light came on.
after parking the bike for a few minuits in the dry it did not come on again
anybody had this problem ?
It means you have an fuel injection error, if your handy you can look up the error code pretty easy, check out the how to section in the maintence forum for a detailed writeup.
HispanicSlammer, Apr 10 2005, 08:31 AMIt means you have an fuel injection error, if your handy you can look up the error code pretty easy, check out the how to section in the maintence forum for a detailed writeup.
Nothing to worry about, I rode my VTEC in the rain and the speedo read nought, then the neutral light came on, then the FI light came on. GPS told me I was doing 75. When I eventually stopped I turned the ignition back on and the FI light worked normally.
It would, from others experience as well, seem that water is getting past the screen edges and wetting the PCB/connectors behind the instrument panel. It has also been found that water enters the speedo sensor on the sprocket cover, this can be cured with sealant.
End of thread · 4 posts recovered Wayback Machine snapshot 25 Apr 2005
