Hi guys Its been awhile since the last conversation. Yet this time it is a crazy one, I''ll do my best to keep it condensed. Last year I got my hands on a very clean low millage VFR that I knew of from a gentlemen that took care of it it was very well less the last couple years where he hadn't time for riding so it sat. Next he decided to sell the beast again I knew what this one was about so made him an offer thinking its going to need the basics to get it down the road. He was getting ready to fire it up and get back into it, but things went in a different direction. then I didn't hear back for a few moths then here he was coming full circle and took my offer Nice 😉 so I thought.
Ok, here we go once it was in my garage the normal fluid changes, plus battery and the complete going over al look good Now it time take it for a spin fired right off so typical Honda 😉 then once out it acted like it was down on power compared to my 98, Then bing GOat 2800 rpms it took off, all was good.... hahah Nope, any time you go below 2800, it kinda goes flat so back to the shop I went. Knowing these critters like i do and know this particular VFR told me since it sat for awhile it could be a fuel injector so into the gunnels we go, while it was opened up, I swapped outall 4 them , button up, lets try this again. PUFF!! only to have the same result. Head -a -scratching had me use a temp gun on the exhausts, yep Number 4 was the culprit, not firing off util the 2800 mark. So the next was done one at a time.
Fuel pump, check pressure checked out along with new fuel filter, check, still does it
ECU swap still does it
ignition coils with leads and boot along with new plugs.. still does it
FPR swap.. still does it.
Here's the weird part, it starts and idles great hard tell its not running on all four, I even did the starter vale alignment, it still does the same after 2800 it's great. I decided to let it act this way for a couple tanks, no change.
Next I modded out the air box so I could get it running less air box to check injectors with a tester of sorts ,that told me as best one could, $#@! those bugger are buried. that they are working, Yet ???
So I got a syringe and squirted fuel in # 4 while running. Wa-La the exhaust temp showed up, so yea its not getting fuel in there below 2800 Hmm?
A double checking that the fuel lines are good,which they are, so now the question is, is it the Injector wire harness? or maybe there's a pulse input thing with the injector mode that isn't working? if so where ?
Thanks for the Listening, If this VFR wasn't so sharp, I'd part it all out.
