Hi Guys.
I know this is diggin up an old thread, but I'm unable to find definitive info for this fork mod as to which combination of valves are best to use.
Anyone done this with good results?
Did you use the full F3 components or a mix of F3 & 5th Gen Valving & install them into the F3 cartridges?
Are the 5th Gen valves identical to F3's?
If so, are they shimmed any differently to the F3's?
Decent used F3 forks are like rocking horse shit over hear in the UK.
Found a pair @ £60, 50miles away, collected during winter months, stripped em down last week, one brass rebound adjuster screw was seized solid, needed a good soak in (Deblock) release fluid, bit of heat from blow torch & the little shit broke free with some gentle back n forth coaxing.
All parts fully stripped/cleaned polished/re-assembled & ready to rock along with a fork service kit.
May need to upgrade the coils, don't know what's in there as yet till I pull my 5th Gen legs apart, all being well, previous owner has fitted some heavier linear coils?
Any input would be most appreciated.👍
