Hi folks,
Have the above kit on the way from Germany (bar that comes with it is very similar dimemsions to the Hurricane police kit bar)
Also have the Hurricane extended throttle cables & choke cable coming from Webike.
My question is : as I've to crack the brake & clutch systems open to fit this kit,these will need bleeding(🫠)
As the bike is 27 years old ,it also makes sense to replace the lines so I'll be ordering braided lines - has anyone got recommendations for the additional lengths to add to the lines while I'm ordering?
(The kit states that Oem lines can be used with reroute but it costs very little for the additional length so if I can avoid that for the sake of €20 I will!)
Full set of lines atm with a discount (till 06/06/25) is working out @ €440 shipped from probrake.de including additional length and choice of colour sleeve.
Attached is dimensions of the bar if this helps anyone who's done a similar conversion and used extended lines steer me in the right direction!
Thanks in advance,
Sean.
