View File
Official Power Commander 2 Software and Maps - From Dynojet
Hi everyone,
New here but I thought I should contribute !
Upon request, Dynojet have provided me with the PC2 software, user manual and maps for the VFR. Thought might be useful to some others as well 😁 !
Here's the reply from Dynojet:
"While this software is no longer supported by Dynojet, you can still download it here: https://drive.google.com/file/d/1Wb8mQeHeao6_k4xkl6ZswDXyVGhYyWKD/view?usp=sharing
It has not been tested with Windows 10, and requires a serial port connection to communicate with those older Power Commander 2/3/3r serial units. The USB to serial adapters, which are common in the marketplace, are also problematic. A true RS-232 serial port is recommended. Also make sure that your serial port is assigned in the port range of 1-8 as our software will not address ports using a higher number than 8.
We also attached the Software User Guide to this email for your convenience.
You need to have a map open in the software that matches the unit you have, before the software will communicate. I have attached all the map files on a zip file, M101-all.zip for this bike to this email. Please extract the zip file to use the MAP files.
Save the maps to your computer, open it in the software, then you should be able to communicate with the unit. The User Guide will have the procedure to send the map.
It uses this map to determine what the bike is, and therefore what the data type is coming in."
I have successfully tested this on my 5th gen with a CHIPI-X10 RS232-TO-USB converter.
Happy tuning !
- Submitter ShinyPants101
- Submitted 06/06/2025
- Category Power Commander Maps
