5th Gen Saddlebag bag supports and a six pack rack
2 posts Started 27 Jun 2025 Last recovered post 27 Jun 2025 Wayback Machine snapshot 7 Oct 2025
Last Sept. I finally got my new to me 5th Gen in running order. Unable to find any hard bags for it I ended up building a pair if saddle bag supports for my soft bags. I used 5/16" - 8mm weldable rod for most of it, with some 1/4" - 6mm for the forward stays. Everything was cold bent on my 6" vise with a 3lb ball peen, then welded. They are easily removable with 4 fastenings per side. I used them on a 3,000 mile trip that Fall and worked well. I did think though that a six pack rack would be helpful.
Not finding anything available for the 5th Gen, and having trips to VA, TN, NC, then 4 days after that up to New Brunswick and the Cabot Trail in Nova Scotia in May, I figured I'd have a go at making a serviceable six pack rack a shot. Again I used 5/16" - 8mm rod for the frame and some 5/8' - 16mm  X 1mm flat for the slats. I piggybacked off the Saddlebag supports to make it easier to mount,  and threaded the rod at the forward end to adjust the rack, but also make it removable. The cable clamps on the aft lower are for the same reason. I can remove the rack in less than 2 minutes, but it is strong enough that a buddy and I lifted the back of the bike off the ground with it. 2 trips and just under 5,000 miles this May, and it has indeed proved useful.
I'm a form follows function guy, so I'm not bothered if its less than elegant. Besides, there's so little in the way of luggage options for the 5th Gen that I had to figure out something if I wanted to go touring
The last pic was taken around the 20th of May at Rouses Point NY as I was returning from NC etc. I generally will go up to the Quebec Border and turn right to get back home. This eliminates going through CT and MA, a far more relaxing way to enter Maine.
[image: 20250623_181257.jpg]
[image: 20250623_181307.jpg]
[image: 20250623_181320.jpg]
[image: 20250623_181327.jpg]
[image: 20250623_181752.jpg]
[image: 20250520_100704.jpg]
Looks great! 👍
The thing I miss most about my VFR is the factory hard bags.  I don't do a lot of trips, but those bags were a godsend for sport touring.  I have struggled with what luggage to buy for my current bike, as I don't love any of the options.  I'm close to making a decision now, but it has taken me a long time to get to this point.
Kudos to you for making your own setup for your 5th gen. since there wasn't anything you liked on the market. 🙂
End of thread · 2 posts recovered Wayback Machine snapshot 7 Oct 2025
