I took my '01 apart 3 years ago to do some deep cleaning and minor sprucing up. I'm one of those doesn't know when to stop and keeps going whenever they see something, and before you know it you have basically a frame with an engine left!
In my case I removed everything from the frame apart for the engine and the front forks. Plastics, tank, seat rear wheel, rear swing arm, rear shock all were removed.
Life events got in the way, plus having another bike to ride, meant that the project really stalled out. I have finally taken on enough enthusiasm, mixed with equal parts of shame, to really tackle the rebuild and get the bike back on the road again.
Aside from thoroughly cleaning every part removed, the following work has been done so far:
Seat recovered and new foam
New chain
New front sprocket
New rear sprocket
Spark plugs replaced
Air filter replaced
Engine oil and filter change
Clutch completely flushed with new fluid
Rear axle cleaned and greased
New thermostat
New O rings on the T-stat housing
New O rings on the coolant hoses connected to the cylinders
New O rings on the water pump (cover and drive shaft).
I have refitted the rear shock, swing arm and wheel.
Rear subframe back on the bike and rear panels fitted.
Coolant pipes and radiators refitted.
Getting ready to deal with the nightmare of installing the throttle body unit.
Before I do that I have a hose that needs to be replaced. The rubber is in bad shape and there is a gash in it. I need to identify the hose so I know what to order, but I am also not sure where either end of this hose attaches to. This hose is pictured and is somewhat unique because at one end is an angled T-piece.
Any help is much appreciated!
[image: 20251005_195614.jpg]
[image: 20251005_195631.jpg]
[image: 20251005_195733.jpg]
[image: 20251005_195658.jpg]
