Hi, so yesterday I thought I'd balance the idle air control valves as I've not been happy with how it's running at idle. Is a pain to start when cold, fires then dies until it finally stays running. Also the idle screw is turned all the way out to get a reasonable idle which I thought was strange. The throttle response is snatchy too. Started adjusting them, I couldn't get #1 anywhere near #2 vacuum reading, I think the nearest I could get it was around 5inHg. Also every adjuster had been wound out so they weren't clicking against the indexed points, definitely not right. So I reckoned something must be blocked, or maybe a vacuum leak but I've not found a course yet. Stripped the idle air control valves down, can see the return spring being a right bastard to reassemble but one problem at a time! All seemed cleanish though, valves moving freely. Will chuck them all in the sonic cleaner tank at work on Monday. My concern is the special coating I've read about on here, supposedly being quite important. Well on mine, I have noticed some of the coating has chipped off in places. I just can't see it making a whole lot of difference myself, what do people think? It's definitely lean at idle too, a quick crack of the throttle causes a lean bog. If it was carbed I'd want to turn the air screw in a 1/4 turn. The ends of some of the vacuum pipes have perished at the ends which could be causing some of the symptoms if they're not fully sealing, will change them all anyway. Will clean the injectors as well, I'll see if I can borrow a mates injector cleaner, be able to see what the flow rate is like then too. I'm hoping to ride it to Assen to watch the GP next year so I want to get it right rather than having problems in a different country!
Cheers
Cameron
