Last Spring the bike randomly started to have cooling issues. Inconveniently I was 350 miles from home. I went through western Maine to avoid Mass Traffic and ended up stuck in traffic because of construction on 84, when I noticed my temp was reading 229-231f. There was no breakdown lane, so I nursed the bike along for 30 min or so until I could pull over.
I confirmed I had coolant in the reservoir and the fan was running hard, constantly. I Let the bike cool down for a while and decided to keep going as I was still 300 miles from my hotel. It was around 95F ambient temp, so quite a bit more on the tarmac, but it started raining fairly hard so I figured that might help. Long story short I pulled in a bit after 9pm into Wilkes Barre and parked up. The bike sat at 219-226 f for the rest of the day. I had skipped a gas stop and ran the bike to 210 miles on the trip Odometer in case I ended up having to have a go at the thermostat, I had all my tools with me if I did.
6am the next day I lifted the tank and started to remove the airbox, when I decided to just start the bike and see what happened. In the cool of the morning it would get to about 185f then drop. It did this for 5 or six cycles so I ran the engine up to 219f (it took a while) fan came on, temp dropped.
I hate it when things fix themselves. I loaded up and did 2,100 miles after with no issues.
4 days after getting home, I headed out with 2 buddies for 1,700 up to Cape Breton and Nova Scotia, no issues.
Parked the bike up for June and July.
Mid August headed to the White Mountains to meet some other friends, ride Mt. Washington, etc. it was 95f here in Maine at noon, never have seen it that hot. Bike ran up to 226-230f until early evening when the ambient temp dropped, then the bike was fine.
Sept. took a 2,800 ride to western PA for a Fall meet, returned via the Adirondacks and Quebec. no issues.
Oct. took a 1,300 mile ill advised ride up to the St. Lawrence in Quebec., never saw above 46f ambient, obviously no issues.
So, a new Thermostat is in order, I'm sure its original as the PO admitted to never working on the bike. I have read Mello Dudes and others excellent write ups on this, so I know whats involved. I have also pulled and installed pretty much all the carbs on my earlier V4's, some multiple times, so not to worried about the TB's. Well maybe the Vacuum hoses😁
BTW, got sticker shock when I went looking for a Thermostat, $52-$75, yikes
Thinking a Radiator flush would be a good idea also.
Lastly, it appears that even when the cooling system is working as it should, it struggles when the ambient temp starts to hit 90f and it cant shed heat quickly enough. I'm looking at installing a lower temp sending unit 210f to help get ahead of that. Thoughts or experience on this would be welcome.
Lastly, when looking at my wiring diagram, I notice the sending unit has constant postive power to it like my earlier V4's, but the ground is routed through the ECU. Why would they do that?
If your thinking this is a long, long post, you are correct, It started snowing here 2 weeks before Thanksgiving and the plow trucks have been by my house 5 times today, Cabin fever has set in.⛄☃️😶🌫️
Michael
