Squidbilly, 1/30/2026 at 9:52 PM
Thanks for your help, Gaz.
Yeah, I'm not really 100% sure on how the rim was damaged. I was on the way to work at about 2030 hrs, it was cold and road was slippery from earlier rain, with a light sheen on the surface, but nothing too drastic. Was about 3 miles from home, so tyres still cold, O/S temp approx 3degC. I went through the roundabout at a speed that seemed appropriate for the conditions, and at the apex she just seemed to slip out from under me. Slid along on her right side for a bit, then flipped over and landed on her right. My best guess at this stage is that maybe a peg/front rim dug in, causing the flip. Although I find it hard to imagine how the rim edge would dig in, given that it should have been protected by the (now unladen) front tire. There was a patch of newly laid tarmac on the exact line that I came in on, so I'm assuming I hit that at maintenance throttle (or maybe I'd wound on a bit early), and lost traction. Didn't notice TCS engage, but could have been missed due to sensory overload, maybe. Still doesn't quite square the circle in my mind as to how the rim damage occurred, but is my best guess at this stage.
The bike had been sitting for about a month whilst I waited for new CCTs from Japan, which I had installed the day before. I did consider maybe low tire pressure, or wheel failure (due to the rim material blowing outward) but these seem unlikely. FOD ruled out (again due to 'outward' damage and no debris noted on surface post-incident.
Luckily, silencer doesn't appear to be punctured. You're right about the peg assby, will have a closer look tomorrow. I'll properly inspect her tomorrow, paying particular attention to the forks, fingers crossed they're in good nick, if not that may make it a write off. If the forks are good, and I've got away with just a couple of new levers, mirror mount (and glass) and a new wheel, then I'll count myself lucky. There's a guy in The States that'll do me a (used) replacement rim for $200 + $80 shipping, but it's apparently got a slight buckle, so he's going to send me a video/pics tomorrow. I'll post them here when I receive them, to get a consensus.
Motorcycle Recycle Breakers is an excellent shout, I'm in Colchester myself, so fingers crossed....
Well Billy, how you describe the events of the off, seems you hit nothing to warrant a destroyed front rim.
A hidden flaw in the rim may have been present in the rim? poss from an off with a previous owner? maybe it just took a bit of a wallop for it to let go, if that's what happened, it's a blessing in disguise.
Personally I wouldn't touch a known bent/straightened bike wheel with a barge pole, car rims are a far more substantial construction & can maybe stand the stress of being cooked by a gas torch & reworked straight, it's a brutal process, Google it, personally I wouldn't risk using a straightened cast alloy rim of any kind.
Re: Buying from USA, anything above £130 GBP gets hammered by import duty, that wheel will quickly end up cost you hundreds & it may be well buckled?.
Trade between UK & USA is no longer financially viable, thanks to the orange oompa-loompa moron, chuck in a cheeky bid on the rim on ebay or ring round breakers.
Re: the above mentioned breakers in your neck of the woods, they state they guarantee all parts as good, you could always as them to verify a wheel is straight while your there.
I'd expect they'll have a wheel jig of some description to spin up a rim or how would they be able to claim a used rim had been inspected for straightness?
Re: twisted forks, forks don't actually twist as such, they bend below the lower yoke, the twist happens within the upper & lower yoke alignment, any off can twist up the yokes, reset em by loosening both lower yoke pinch bolts, this often results in an audible crack, grab the front wheel between your knees & flex the bars a bit in both directions, this may result in an audible crack too, that's the twist coming back out the yokes, bounce the front thru its stroke several times, put bike onto centre stand & torque up yoke pinch bolts, this is usually enough o untwist the yoke alignment, you may also need to slightly loosen the upper yoke centre steering nut a tad & bounce it again, this will also help the yokes realign, obviously bike needs to be sat on 2 inflated tyres for this process.
Shame bike uses the newer style rims, if your'e stuck for a rim, based on the cheap prices used, I'd test fit a 5th/6th front rim using your own axle & spacers, good chance it'll fit as a temp measure until u locate a good used 8th Gen rim then sell on the other rim.
