Datel Digital Voltmeter install, 98 VFR 800
Parts: Red LED voltmeter - DMS-20PC-1-DCM $50.00
Bezel and gasket, screws - DMS-BZL4 $6.00
Retaining clip - 39-2165105 $2.00
Male / Female connector - $2.79
Flux and solder, wire shrink wrap, tie wraps
2 cans Vanilla/Cherry Dr. Pepper, beef bones and rope toy for supervisor
Datel has changed their website to cd4power.com, and it looks like they have a minimum quantity requirement for orders. I ordered these parts 5 months ago before the change, so I'm not sure on being able to get single quantities.
I chose to mount the voltmeter on the left fairing, beside the gas tank. Easy to see without having my tank bag or elbows in the way. I also am using an existing relay wiring for my Heated grips, to turn on the voltmeter with the ignition. The draw from the voltmeter is low enough to be left on all the time. But being a VFR, I trust nothing that maintains a constant draw from my electrical system. The voltmeter power source is spliced and soldered in from the relayed power wire.
1. Starting out, open can of Dr. Pepper, and make sure the Quality Supervisor has ample toys and beef bones to ensure a smooth and trouble free install.
http://www.damonwells.com/motorcycle/datel_install/supervisor.jpg border='0' alt='user posted image' />
2. Using the gasket as a template, and a Sharpy fine tip pen, mark the outline of the hole for the voltmeter, and screw holes for the bezel mounting. Remove the fairing.
http://www.damonwells.com/motorcycle/datel_install/template.jpg border='0' alt='user posted image' />
3. Using a Dremel, carefully cut the hole, too small at first, and slowly expanding the edges out so that the voltmeter unit will fit tightly inside the hole. After the hole is cut to the correct size, drill out the screw holes with a slightly smaller drill bit then the diameter of the screw threads. This forces the screws to be tightened through the fairing before making contact with the bezel threads.
http://www.damonwells.com/motorcycle/datel_install/cut_hole.jpg border='0' alt='user posted image' />
4. Since the fairing will have to be removed for oil changes and etc., I'm using a male/female connector for quick disconnects to allow complete fairing removal. Crimp, solder and shrink wrap two circle connectors to the male end of the wire harness. The circle connectors will attach to the voltmeter screws on the back side of the unit.
Splicing into the existing relayed wires for the heated grips, attach the female end of the disconnect. Solder, shrink wrap and seal with rubber sealant. Attach male and female connectors, turn on ignition and test unit. Use tie wraps to secure mess of wires.
http://www.damonwells.com/motorcycle/datel_install/splice_test.jpg border='0' alt='user posted image' />
5. Install the voltmeter with wiring harness attached., and gasket into the fairing. I notice that I screwed up the alignment of one of the screw holes, crap. Redrill and live with a loose fairing hole. Quality supervisor is gonna chew my rear for that one.
http://www.damonwells.com/motorcycle/datel_install/gasket_install.jpg border='0' alt='user posted image' />
6. Remove protective plastic cover from voltmeter, mount plastic bezel and tighten screws into bezel. Mount retaining clip on backside. Using a hot glue gun, I seal the areas where the wires enter the male / female connectors to keep most of the water from entering. Water can still enter where they connect together, but I can live with that.
http://www.damonwells.com/motorcycle/datel_install/retaining_clip.jpg border='0' alt='user posted image' />
7. Connect the wiring harness to the bike, replace the fairing. Turn on ignition and retest.
http://www.damonwells.com/motorcycle/datel_install/final.jpg border='0' alt='user posted image' />
Call Quality supervisor over to give final sniff and slobber of approval, job is now complete.
Things I learned:
- Cutting into the fairing is not as scary as I thought.
- I still suck at doing quality soldering. I need a better soldering gun.
- Next time, have beer instead of Dr. Pepper.
- Bribe quality supervisor with better toys during install.
Total install time: 3 hours
