stripping rims
30 posts Started 18 Dec 2005 Last recovered post 21 Dec 2005 Wayback Machine snapshot 19 Oct 2006
I have been out in the garage stripping my rims. Like in HS tutorial I left the tires on. I am just stripping the outer smooth surface, leaving the spokes and rough parts black for now. Just to see how it looks.
My question is this. Obviously there is going to be some stripper getting to the tire by the bead no matter how careful one is. Will this soften or eat away the rubber? I don't want to be taking some corner and have my tire come off ya know?
Didn't have any effect on mine when I did it...
edit - I should mention that I did tape off the tire with a few layers of masking tape however.
Just wash it thoroughly - that's what I did. I *did* put masking tape round my tyres first though, and put vaseline or summat (can't remember now) where I missed bits, but in hindsight, it was a waste of time and effort.
One thing to note is that when you next have your tyres (or tires, or tahrrs) changed, you'll have some messy bits under the tyre beads, where the stripper didn't reach. The tyre technician kindly cleaned these off for me, at no charge.
Next time, I'll either strip my rims when the tyres need changing, or get the tyres removed and replaced. It would be much easier.
I had the tires on when I stripped mine and didn't mask anything. I have had no probs to speak. I think you will be fine. cool.gif
Hey tele..
Not that there aren't a few already, but post pics when have finished your process.. The more pics the more it pushes me to do this. I have always liked the polished lip look and have been very close to doing this. Thanks....
Good luck...
The stripper should not harm the tire rubber.. but, call the manufacterer t'morrow of either the stripper or the tire rubber, and I would assume they could easily answer what chemicals affect and which ones do not... Good Luck.. beer.gif
OK..here are a couple of pics. Granted it is not on the bike as I am thinking of stripping more areas. I wanted to do a little at a time. If anyone has pics of their rims with the black and polished look, please post so I can get other ideas.
[image: user posted image]
I don't see the wheel ??????
One of the things that has kept me from doing this on the outer edges (polished part) as you have done, is that I am afraid that the paint edge left on the center part won't have a clean edge. I love the look of the rims being polished on the outer parts of the rim and leaving the centers painted. I just can't convince myself that I will leave a clean edge.
the only part that was not real clean was on the backside of the rim where the polished edge meets the rough surface and it was not uniformly straight if that makes sense. The bottom of the spokes was not "perfect" but certainly acceptable.
That looks really sharp!
(Had to look twice to see the wheel though... tongue.gif )
ok ok...I thought you were talking about stripping your RIMS...
I have seen strippers before!! Although that was a cute little brunette stripper... beer.gif
Whoops.. I scanned back up to bid farewell and good night to my newfound stripper friends, and BAM...there were pics of wheels in that post...
hmmmm... They look sharp... I was hoping to see the front as well... Although, I am a bit curious on what the backside of that rear wheel looks like. I am gonna run out to the garage and check out the back side and make sense of the rough to smooth border you mentioned.... wink.gif
well I sure don't know how the rest of you made it so easy to use stripper on your wheels. My paint is like a rock and I know for darn sure I don't want to tackle the nooks and crannies. No stripper I have tried will "cook", flake or otherwise remove this paint. It barely softens it to scrape it off. So today I resolved myself, since I have no one within an 8 hour drive that can dip my rims, that I am going to blast and powdercoat. Even the bead blasting took FOREVER and its still not all off of the back of the rim.
Then to top it off, my local powder coater, said it could take 2-3 weeks for me to get one rim back.
Any color suggestions for the fastest yellow VFR? I was thinking of chrome smoke like a pic I saw posted on here not long ago.
Does anyone remember who posted the pic of chrome smoke powdercoat rims?
Here is the photo I am referring to.
actually that photo is an Eastwood color. The caswell is not bad either though. Thanks.
teleskier, Dec 19 2005, 10:37 PMactually that photo is an Eastwood color. The caswell is not bad either though. Thanks.
So is that topcoat 'translucent gold'
( http://www.eastwoodco.com/shopping/product...48&iProductID=7 )
or some other product? I haven't found 'chrome smoke' yet.
Correction--just located it! Thanks
teleskier, Dec 19 2005, 09:44 PMDoes anyone remember who posted the pic of chrome smoke powdercoat rims?
BTW, it was kerry_129, but you probably got that already.
teleskier, Dec 19 2005, 10:44 PMDoes anyone remember who posted the pic of chrome smoke powdercoat rims?
It was user kerry 129
Here's a link to the powder: http://www.eastwoodco.com/shopping/product...ProductID=11330
And here's Kerry's earlier post on that same topic:
http://www.vfrdiscussion.com/forum/index.p...ndpost&p=189235
teleskier, Dec 19 2005, 11:39 PMwell I sure don't know how the rest of you made it so easy to use stripper on your wheels. My paint is like a rock and I know for darn sure I don't want to tackle the nooks and crannies. No stripper I  have tried will "cook", flake or otherwise remove this paint. It barely softens it to scrape it off. So today I resolved myself, since I have no one within an 8 hour drive that can dip my rims, that I am going to blast and powdercoat. Even the bead blasting took FOREVER and its still not all off of the back of the rim.
teleskier,
If you decide to powdercoat them, take a look at my post:
My Wheels
The guy I used will do them for $100 which includes stripping, powdercoating, and putting clear coat on them. Just pull out your valve stems and wheel bearings. He can do just about any color you want, but has black, silver, and a few basic colors on hand.
Take a look at Columbia Coatings web site. This is where he gets all of his stuff. They have some cool looking "mirror black" and "black chrome" colors. He may charge a little more for special order colors, but he would definitely be fair on the price.
Columbia Coatings
Wow!! That sounds like a great price... After looking through Columbia Coatings website, i am getting those "Gotta find something to powdercoat" jitters...
Hmmmm.... Can I powdercoat my dog?? I think she would look good with a nice set of super Mirror Black ears... tongue.gif
Not sure if you knew this but as you mentioned you had a hard time getting the factory paint of?f well I too had that problem . Well problem solved, get the stuff Eastwood makes, called DeKote. took 4 applications but never used not,not all that bad to use sorta like yogurt doesn't have that knock you out smell either, great stuff, Highly recommended.
teleskier, Dec 20 2005, 04:39 PMwell I sure don't know how the rest of you made it so easy to use stripper on your wheels.
I don't know that I would say it was "easy"; it did take some hard work and lotsa elbow grease. But the stripper certainly worked OK, even if it did require a few applications. Took me most of a day to do both wheels.
The old VFRWorld web site has a great section on stripping wheels. Even gives recommendations on the brand stripper to use (the kind with the airplane on the can) lots of pix too.
Here is what I used and I think this is what fuldogg is referring to. It only took one coat and it bubbled up nicely and wiped off with a damp sponge. I also did the outer edge of my spokes in the rear. See Gallery. Hope this helps.
Wheel Stripper
Looks pretty clean skier.
If I decide to strip my lips, is there something I have to treat the metal with to keep it from rusting, and to keep the paint from chipping?
BigRoach, Dec 21 2005, 09:37 AMLooks pretty clean skier.
Aluminum doesn�t rust
cozye, Dec 21 2005, 09:51 AMAluminum doesn�t rust
Of course... I knew that.... What do you take me for?.... Has anybody who has left their rims like this had any problems with the paint chipping at the edge?
I tried Jasco, Airplane stripper and a brand I used to sell that is stronger than Jasco and no luck with any of them. I sure wish I could have wiped it off with a sponge like some else mentioned. I spend 6 hours on one wheel and it was only half done.
End of thread · 30 posts recovered Wayback Machine snapshot 19 Oct 2006
