remus install ?
6 posts Started 27 Jan 2006 Last recovered post 28 Jan 2006 Wayback Machine snapshot 15 Feb 2006
you guys that put remus exhaust on, is there a gasket that suppose to go on the cat before you slip the pipe on or does it just go on with out one? thanks, buy the way they sound bad azz
driggs, Jan 27 2006, 06:13 PMyou guys that put remus exhaust on, is there a gasket that suppose to go on the cat before you slip the pipe on or does it just go on with out one? thanks, buy the way they sound bad azz
Driggs - I don't have REmus - but I did Ask that question - and from what I recall - there is NO gasket - I think it is just a compression fit.
Depends on how tight the fit is. I have a 5th gen with a staintune, and there is no way that a gasket is going to fit between the collector and the midpipe. But if there is slop, you either need to use a gasket or use some high temp exhaust silicone. Install it with no gasket first and see if you have an exhaust leak, if you then have a leak, try putting some sealant in there and see if that stops it.
I've got the Remus - no gasket. It's been almost two years so I struggle to remember... but I think I put some super high-temp goo on there anyway.
The older they get the better they sound. I've got about 24K on mine now and they sound better than ever.
It doesn't have a gasket. Mine fit nice and the clamp sealed everything right up. I didn't need any "high temp goo" for mine. smile.gif
tbzep, Jan 27 2006, 08:39 PMIt doesn't have a gasket.  Mine fit nice and the clamp sealed everything right up.  I didn't need any "high temp goo" for mine.  smile.gif
+1.gif Mine fit nice and snug without any "goo" as well.
End of thread · 6 posts recovered Wayback Machine snapshot 15 Feb 2006
