Battery Drain
Maybe that Amp sucking horn you installed recently http://www.vfrdiscus...tyle_emoticons/default/wink.gifAny other ideas?
<{POST_SNAPBACK}>
I had the sub-standard stator and after killing the battery enough times, a cell in the battery calfed. I had the stator replaced along with the battery and it runs beautifully now.
So I think my problem was just the cold weather. I've not been riding for about a week now even though it's been getting warmer (tsk, tsk, yeah, I know, I know) and this morning I was able to fire up the V4 without a problem AND I had the alarm on the entire time. So I guess my battery doesn't like cranking the motor after sitting for even just two days in 25 - 30 degree overnight weather. :blink:
<{POST_SNAPBACK}>
Hmmm how old is your battery? typically unless of course you do find a culprit that is stealing AMP's at night, a battery will decline like that after the cells lose their ability to retain the charge... Big battery advocate here, i just sold a GEM car, they are electric golf cart /road legal cars.. anyway they use 6 deep cycle batteries and that was a big issue with them...
FYI: i am researching a battery for the VFR right now, they will be pricey,, however they are "DRY-CELL's" with about 6x the cold cranking amps of our current wet cell and maint. free VFR batteries! :unsure:
Michael
The battery is original. The bike is 3 1/4 years old with 12K + miles.
<{POST_SNAPBACK}>
Could be that your battery is just exhausted, i know i replace my lawn tractor battery every 2 years it dies, and the bike batteries are smaller. you can buy a battery tester at wall mart or any place really they are like a buck... they measure i believe the specific gravety of the acit in each cell. this will tell you, or better yet pull that puppy out head up to autozone and have them bench test it...
Michael :unsure:
Looks like you have a VTEC. Did you have the stator recall done?
I had the sub-standard stator and after killing the battery enough times, a cell in the battery calfed. I had the stator replaced along with the battery and it runs beautifully now.<{POST_SNAPBACK}>
Stator Recall? What's the deal with that and I wonder if the recall already expired. I did a search on the forum and couldn't find anything.
Chris
Call any Honda dealer and give them your VIN# they can see if it has been done, and if not, they can do it.Stator Recall? What's the deal with that and I wonder if the recall already expired. I did a search on the forum and couldn't find anything.
<{POST_SNAPBACK}>
I replaced the battery. :thumbsup:
It has been going strong for over a year now.
I don't know anything about a stator recall for an '03, but if your motorcyle is registered with the DMV, and it was affected by the recall, you would have received notice. If you want to check, go to http://www.recalls.gov/
When the 2002 VFR had a stator "recall," Honda just quietly announced it as a "model upgrade." OTOH, any 2002 VFR owner (even 2nd and 3rd owners) could bring it in for a new, free stator and, get this - you have 7 years to get the service done! No complaints, even though they didn't denominate it a "recall." Larry
<{POST_SNAPBACK}>
If you don't use something like a Battery Tender most of the time a 3 year old battery is getting old !!!
Stator recall was on 02-03's and the up-grade did NOT increase Output at all, all it does is start charging sooner(lower RPM). If you did lots of city driving with high beams on and or several accessories, you could have a charging problem on the original Alt.. Also riding at any speed with lots of accessories and the High beams on will cause a drain on the battery because there's not enough extra watts to charge the Battery too ! I think there's less than 200 extra watts available and just running the high beams take 100 ! http://www.vfrdiscus...tyle_emoticons/default/+1.gif
I have 34k miles on my stock stator/alt. w/ no issues. I run Gerbing jacket liner(77watts) and socks(22watts), heated grips(? watts) radar detector. If I also run high beams it won't charge the battery, even at 11,000 rpm !
<{POST_SNAPBACK}>
The Dealer would add a Punch mark on the Vin. tag to indicate the recall was done and another punch to indicate that the rear subframe recall was done. I don't remember what corner of the tag each make was placed.
These may not have been true Recalls, so they might not be listed on the Recall site mentioned. All the info here was lost or deleted.
Google it ! http://www.vfrdiscus...tyle_emoticons/default/+1.gif
Interesting about the subframe recall. I asked Honda Australia about mine (an early model 2002) and I was apparently fixed on the production line - the 60th one after the fix was applied, apparently.The Dealer would add a Punch mark on the Vin. tag to indicate the recall was done and another punch to indicate that the rear subframe recall was done.
<{POST_SNAPBACK}>
No word on stator recalls here in Aus though. Any other Aussies here get their stator replaced - or even notified?
Kaldek
