#1 Thread starter
emoe, Oct 22 2006, 09:12 AM
Ok i changed the R/R and now i get 10.7 volts!! WTF?
is that the only way i can check the stator windings?
See the electrical system tests here:
HS' how-to guide
Also, inspect all your grounds and connections; be sure they are clean, free of corrosion and secure.
Make sure the battery is fully charged and in good condition before troubleshooting (load tested if possible).
The stator test is a measurement of resistance between the three stator wires.
ElectroSport has some fault-finding charts here:
ElectroSport
