OK, the thread is getting long. I am going to do a brief recap and update my Parts Used list.
Frankenviffer's Checklist:
1. Forks
c. R1
2. Wheels
These are various five or six-spoke front wheels that are a good cosmetic match for the OEM rear wheels
a. OEM
3. Wheel bearings
a. OEM
4. Wheel spacers
b. Left outer: Custom, ordered from www.misumi.com
c. Right outer: Custom, ordered from www.misumi.com
5. Rotors
a. OEM
6. Calipers
f. Yamaha R1/R6/FZ-1/Warrior
7. Front Brake Master cylinders
a. Honda CBR600F4 (front)
8. Rear Brake Master cylinders
a. OEM
9. Lower triple clamps
b. CBR929/954
10. Upper triple clamps
b. Vortex / '00-'01 RC51
I used this to get the clip-ons as high as possible so the clip-ons do not interfere with the instrument cluster. I do noe like the looks of the 929 Top Clamp with a spacer under it.
11. Steering head bearings
Tapered bearing kit from Allballs Racing
12. Clip ons
Cycle Cat: Suzuki Hayabusa
Altered: Needed to shorten the tubes and redrill the holes for the control boxes. Moved everything in by .750 inches.
Also, because of tight clearance issues, the brake lines and clutch line needed to be re routed, via Goodridge Custom ends from Dennis Kirk. I used the ones where you get to pick which end you want, them attach the correct length line.
13. Front Axle
Custom made. A turned down R1 axle was too scary for me. My axle is now solid Stainless Steel
14. Brake Lines
Goodridge custom length lines.
36" on the clutch, 90° banjo fitting at the top, 25° banjo fitting at the bottom.
28" on the left brake caliper, 90° banjo fitting at the top, 15° side angle banjo fitting at the bottom.
25" on the right brake caliper, 45° banjo fitting at the top, 15° side angle banjo fitting at the bottom.
These are a little spendy, but they are the right length and have no kinks to deal with. Figure $12 per banjo and $32 per line. Don't forget new crush washers either.
I am going outside now to take some pictures. Wish me luck.
Edited March 14, 2007 by DonnyBallGame
