Throttle Cable Rubbing
4 posts Started 4 Nov 2006 Last recovered post 13 Nov 2006 Wayback Machine snapshot 29 Mar 2007
There you go: get some gold chrome spiral wrap. That shite would be blingin' for sure!
Found it. $2.25 at Home Depot for a lot more than I needed. I'll find a use for the excess somewhere.
I only ask because the bike can be turned all the way to the left when backing out of a spot. The engine is running and I may give it some gas. Well...if cranked all the way left, the throttle sometimes sticks open. That is, till I turn ever so slightly to the right then it frees up right away. There isn't much routing to check, really.
Phaedrus.
767fixer, Nov 12 2006, 11:55 PM
mine never bound.....you may need to check the routing....
Phaedrus, Nov 13 2006, 12:21 AM
Phaedrus.
although not a lot, it should still not bind....id lift the tank and look at the cable run for safety measures
End of thread · 4 posts recovered Wayback Machine snapshot 29 Mar 2007
