Need Help! Cannot Sync. 91 Carbs.!
2 posts Started 17 Nov 2006 Last recovered post 13 Dec 2006 Wayback Machine snapshot 29 Mar 2007
buddie hackett, Nov 17 2006, 11:21 AM
You have a air leak . I imagine. Try spraying wd40 on the running bike on the intake runner/boot and if the motor speeds up or slows down you have yourself a leak. Or vaseline all the joints on the intake(external) and start the bike. If you develope bubbles in the vaseline your pulling air thru.
I like to go simple then complex when it comes to digging in to carbs.
no no! spay CARB cleaner or starting fluid.. it WILL rev higher if you have a leak...
My 1991 has an extremely high idle, and will run hot unless I contain it, I say we get to the bottom of this, and let everyone else know that they are chumps.
Dirtydizzogg
End of thread · 2 posts recovered Wayback Machine snapshot 29 Mar 2007
