Frame Sliders For A Vtec - Need Help.
26 posts Started 21 Jan 2007 Last recovered post 28 Sep 2007 Wayback Machine snapshot 7 Jul 2017
I am considering installing some custom frame sliders on my 02, and am just measuring up the location for the hole.
My concern is that the location on the fairing that I need to drill, does not leave any margin of connected plastic, once drilled.
THe dot in the centre of the yellow dot - is the centre of the hole. From there - the hole will be 3/4 inch in all directions. (The hole saw is 1 1/2" )
[image: IMG_3677.jpg]
My fear is not in drillign the holes, its what the fairing will do after in terms of stress cracks because it has been compromised.
Radar in Saskatoon has sent me a kit to use to drill the holes, and he has made an aluminum base that will bolt to the engine bolt, and then the solid Delrin slider mounts to the aluminum.
ANyone that has a close up of the hole they drilled - or even a shot of where they mounted their sliders for a 6th gen - I'd appreciate seeing that.
Feedback is needed......
thanks
Well, if you get stuck, the simplest thing to do would be to turn the base and slider down some more in the lathe, making the diameter smaller, and then use a smaller hole saw. Taking .062" off the slider in the lathe will buy you 1/8" on the hole size, which will leave you with a little bridge of plastic left on the fairing, which you could reinforce from the rear with a piece of small diamter metal rod and some fiberglass resin.
That's my two cents, anyway.
Ken thats going to be pretty close to the vent opening in the fairing. Is that what your concern is? Your driiling into the fairing from the other side though right? What does RAdar have to say? I see your concern but dont have a solution other than check 20 times cut once :huh: Oh and whose holding the flashlight? +1.gif
Perhaps there is some way to reinforce the fairing from behind prior to drilling. I am not sure if fibreglass with stick to the type of plastic that our fairings are made of, but I would think about putting a layer or two of epoxy fibreglass on the inner surface of the fairing for extra strength around the hole. I think the fairings are made of ABS plastic like the black drain pipes, but I don't know for sure.
I would also be sure to put packing tape over outside surface when drilling to help prevent any chips from drilling the hole.
I wouldnt be drilling inot the open space of the fairing. Hold off for now is my recommendation Ken.
thanks guys, I'm in a holding pattern for now. DUDE - I will be drilling "AIR" as in the opening of the fairing. I don't think thats a smart thing to do.
Seb - your suggesstion is how I'm thinking this needs to go.
Heres a pic of Radars slider:
[image: med_gallery_8807_2171_399455.jpg]
I think the aluminum base is too large for the 6 gens to work. Maybe this needs to be more like the R&G slider - in that a small diameter bolt goes through the fairing, with the base attached to the end of the bolt - and then the Delrin slider attached to the base.
I'll wait and see what Radar suggests..
like what dude ways, the hole looks awfully close to the rad opening...
Ken see dirtbags pic? Thats where it needs to be located!!!
dudeKen see dirtbags pic? Thats where it needs to be located!!!
Gary go over to Ken's and do it for him, err help him. Ken get the flashlight ready. :P
Here's what I have Ken.
This is a picture of it installed (and crash tested, for that matter :P).
[image: gallery_3392_431_10360.jpg]
Another picture of the location
[image: gallery_3392_431_340584.jpg]
A close up shot of where the pilot hole was drilled
[image: gallery_3392_431_411562.jpg]
This is the engine mount for the Motovation sliders.
[image: gallery_3392_431_113687.jpg]
Maybe I do need to get in the car and head to Kanada. . .
Well - I appreciate the vote of confidence and support CBR boy.....
Looks like OXmoles slider attached to the other engine bolt. If that is the one to use - then this will be a piece of cake.
I was of the impression to use the forward most bolt. THanks again!!!
Kanadian KenWell - I appreciate the vote of confidence and support CBR boy.....
No problem flashlight boy. :goofy: Ken go with Dale's suggestion. Obviously he has a lot of experience with intalling sliders. He also has experience using them but I wouldn't necessarily ask for that advice. :P
In defence of what might appear to be a lack of my mechanical skill, I just reread the instructions, and I was following them to the letter. I am however one of the worlds best light holders for people that really know what they are doing - like Dude and MCREW!!!
I think that as my bike is the prototype "donor" for 6th Gens, this is exactly what we needed to find out before Radar makes these up in quantities to sell.
5TH Gen bikes (what Radar has) use the forward of the two top engine bolts. It seems to me that the 6TH Gen bikes need to use the other (back) engine bolt so as to not weaken the plastic around the rad opening.
I'll post up with pics and a step by step once we work through this "hiccup".
It was fun being in the garage though - had the propane heater going, the radio on, and some time to myself.... I avoided the beer though - but now that the projects on hold......... :beer:
Kanadian KenIn defence of what might appear to be a lack of my mechanical skill, I just reread the instructions, and I was following them to the letter. I am however one of the worlds best light holders for people that really know what they are doing - like Dude and MCREW!!!
Ken you can hold the flashlight for me anytime. :thumbsup:
The rear bolt, for sure. Wouldn't worry 'boot stress cracks. DRILL IT FROM THE BACK SIDE, or you'll prolly regret it.
Ken, just remember to drill a small pilot hole, get hole large enough to bolt up slider base to the outside with fairings mounted, take a black sharpie marker and trace around base of slider, use a dremel tool, I used the little sanding drums, and go very slowly, cutting the hole larger to let these sliders drop in, my job was very tricky but took my time and turned out perfect, are R & g s but same concept, wireless will has some great pics, just go slow and a Dremel tool is a must here, not a gadget , thanks doug
This thread is the exact reason VFRD is such a good web site! I'm looking at installing frame slider in the spring and have just had a number of questions answered. Y'all really know your stuff... well, most of you really know your stuff!
767fixerthank god ken that you actually asked questions before cutting!!! totally unlike some aircraft mechanics i know:)
hey whats that supposed to mean?!?!
well, i guess if you saw the bell 214 helicopter i work on right now(in the middle of winter maintenance...), you would probably have something wink.gif
DougFromIndyKen, just remember to drill a small pilot hole, get hole large enough to bolt up slider base to the outside with fairings mounted, take a black sharpie marker and trace around base of slider, use a dremel tool, I used the little sanding drums, and go very slowly, cutting the hole larger to let these sliders drop in, my job was very tricky but took my time and turned out perfect, are R & g s but same concept, wireless will has some great pics, just go slow and a Dremel tool is a must here, not a gadget , thanks doug
Ken this is great advice. It will take a bit longer than the Roto-Rooter you were going to use but will look much better and minimize any chance for damage. :thumbsup:
Radar has created some amazing tools that take ALL the guesswork out of cutting the pilot hole, and the hole for the slider base. I'll let him share the tools he's designed.
No lasers, play dough, putty, paint needed to do the locating of the holes. IT is a SLICK system.
I'll post more on this once I get done.
THanks for all the suggesstions - I appreciate it. :thumbsup:
4strokeThis thread is the exact reason VFRD is such a good web site! I'm looking at installing frame slider in the spring and have just had a number of questions answered. Y'all really know your stuff... well, most of you really know your stuff!
That's 'cause we dont' want to see others cut the beautiful bike to ribbons, like we have. LOL.
Kanadian KenRadar has created some amazing tools that take ALL the guesswork out of cutting the pilot hole, and the hole for the slider base. I'll let him share the tools he's designed.
Now THIS is something I want to see. If it takes the "Damn, I hope I'm right about this" out of it, it's worth a fortune!
VFRD come thru again. Good for you to post up instead of being mr macho guy and friggin things up :thumbsup: Leave bolt breaking and shit to me :goofy:
an easy way to centre the hole is to glue a tack(or similar device, with an easily removed adhesive) to the end of the bolt and back it out enough to hit the fairing. light tap with hand/rubbermallet and pretso whamo there is your centre.
:rolleyes:
End of thread · 26 posts recovered Wayback Machine snapshot 7 Jul 2017
