i swapped 5th gen VFR's with my girlfriend the other day...and her beat-to-shit, 65k bike steers into turns with less effort than mine, by quite a lot.
i know tires and suspension settings have quite a bit to do with this, but it felt like more than that.
are steering bearings something people modify frequently on 5th generation VFR's? mine feel okay, no jerking/rattling or anything...
i have just over 40k miles. should i repack the ones i have? are there kits for this?
maybe i'm just freaking out 'cause my bike's been trouble-free for the last 20,000 miles, and i feel the need to fix something smile.gif
I know the turn in difference between an M-1 and a Z-6 is wayyyyyy different. The M-1 is more triangular in shape and turns in real easy(almost too easy), the Z-6 requires more leaning force to turn in. Both tires are Metzlers. Tire pressure can also make a bigger differance than one might think.
Teague, Mar 2 2007, 03:57 PMEasy solution, lower your front forks around 4mm at a time until it turns into a corner the way you want it to.
I lowered mine about 8mm from what it was from the factory and the steering is much improved, especially with slow speed manuevers.
Maybe you should edit your post (as Teague did), to avoid confusion. To quicken steering you lower the front end by raising the forks in the triple tree.
End of thread · 8 posts recoveredWayback Machine snapshot 4 Mar 2007
