Will A Cbr 929/954 Rim Fit On A 5th Gen?
13 posts Started 13 Mar 2007 Last recovered post 14 Mar 2007 Wayback Machine snapshot 22 Mar 2007
If anyone knows can you please let me know, my local shop has (IMG:style_emoticons/oldemoticons/fing02.gif) a new one and they are selling really cheap, thanks in advance for your help. (IMG:style_emoticons/oldemoticons/fing02.gif)
It is not a direct bolt. The VFR uses a 20 mm front axle while the CBR929/954 uses a 25mm axle. You'll need to put some VFR bearings (or similar) into the CBR wheel. The bearings should swap over no problem.
As for the brakes, I really don't think so. You best option is to keep the VFR brakes, but that depends on if the bolt patterns much up. If they do, you can put your VFR discs onto the CBR wheel and add spacers accordingly. But, if you want to use the CBR discs, that's probably not going to work at all. The VFR forks are much closer together than the CBR forks.
The only direct replacement front wheel that would allow use of the stock rotors, axle, spacers, brakes on a VFR800 if the 99-00 Honda CBR F4. The F4i wheel and rotors may also work as I think the rotor Dia. & off-set is the same. (IMG:style_emoticons/oldemoticons/unsure.gif)
No-go on the 929, it has 330mm rotors!!
SEBSPEED, Mar 13 2007, 11:37 AMNo-go on the 929, it has 330mm rotors!!
And the bolt circle isn't even remotely close, so you can't bolt VFR rotors to a 929/954 wheel.
929/954 and RC51 have the exact same rotor carrier bolt circle, but 330 mm rotor diameter for the CBRs and 320mm diameter for the RC.
Man you guys are the best, I owe you each a beer (IMG:style_emoticons/oldemoticons/beer.gif)
Someone I know is selling a new 929/954 wheel for $125, and yes the rotors are new new too. It was bought by a friend of mine and he's looking to get rid of it. Do any of you guys have a use for it? If you do I can hold it for anyone that might want it. I figure the rotors alone are worth the money?
Dino71, Mar 13 2007, 12:45 PMSomeone I know is selling a new 929/954 wheel for $125, and yes the rotors are new new too. It was bought by a friend of mine and he's looking to get rid of it. Do any of you guys have a use for it? If you do I can hold it for anyone that might want it. I figure the rotors alone are worth the money?
That's more than worth it, if they're as described. (IMG:style_emoticons/oldemoticons/fing02.gif)
Maybe someone who is doing a VFR USD front end conversion would like it. ???
veefer800canuck, Mar 13 2007, 06:23 PM
It's just too bad it'a a three spoke wheel, it will look funny with the five spoker in the rear...
But hey, Dino, I'll take the wheel! (IMG:style_emoticons/oldemoticons/fing02.gif)
Dino71, Mar 13 2007, 02:41 PMMan you guys are the best, I owe you each a beer (IMG:style_emoticons/oldemoticons/beer.gif)
FREE BEER? Wait I got an answer too!
If a 3/4 gen wheel/rotors will bolt up to a 5th gen (does it?), then a cbr600f3 wheel will also.
FotoMoto, Mar 13 2007, 06:38 PMFREE BEER? Wait I got an answer too!
They don't.
5th gen has a slightly larger bolt circle. Same as F4. (but not F4i)
F4i has same 296mm diameter as gen5, but same bolt circle as 954/929/RC51. Swap away, my little grease monkeys.
Sam Adams Honey Porter please...
thx1139, Mar 14 2007, 07:47 AM
They don't.
Well, there you go Dino71. Get the CBR929/954 wheel, swap the bearings out with VFR800 or CBR600F4 bearings, and put CBR600F4i brake rotors on it. Shim and space brake calipers/rotors as necessary to achieve perfect fit. Then sell the CBR929/954 rotors on ebay to help recoup costs.
I don't believe any extra shims/spacers are required. Just screw together & ride.
Thought I was wrong once, but I was mistaken. heh.
End of thread · 13 posts recovered Wayback Machine snapshot 22 Mar 2007
