Gearing
4 posts Started 14 Mar 2007 Last recovered post 15 Mar 2007 Wayback Machine snapshot 26 Mar 2007
I could't find anything on alternate gearing, specifically on 3rd 'n 4th gens. So here goes-
What does dropping a tooth on the countershaft sprocket do for actual, corrected MPH, top gear at say 7000rpm?
Same question for adding a tooth to the rear with the stock front sprocket, again at 7000rpm?
How about adding two teeth to the rear with the stock front sprocket, and again at 7000rpm?
Someone out there must have changed gearing along these lines. I'm only interested in factual speed after mods.
ex TZ tuner, Mar 14 2007, 01:50 PMI could't find anything on alternate gearing, specifically on 3rd 'n 4th gens. So here goes-
Top gear at 7000 RPM...
...stock = 95.7 MPH
...one-tooth down up front = 89.7 MPH
...one-tooth added in back = 93.5 MPH
...two-teeth added in back = 91.4 MPH
You can download my gearing calculator here: Linky
MFP-2241, Mar 14 2007, 02:57 PM
...stock = 95.7 MPH
Thanks Tim! See you soon
Jabez
ex TZ tuner, Mar 14 2007, 02:02 PMThanks Tim! See you soon
Jabez
End of thread · 4 posts recovered Wayback Machine snapshot 26 Mar 2007
