2003 Vfr800: Battery Replacement
40 posts Started 26 Mar 2007 Last recovered post 17 Jun 2011 Wayback Machine snapshot 7 Sep 2013
Read in another thread that the Yuasa YTZ14S (meant more for the ST1100 and ST1300) is actually a better battery for the 6th Gen VFR.  Is this the consensus?  The dimensions are identical according to Yuasa's website.
Here are the spec variations:
YTZ12S
Voltage: 12 Capacity (Amp. Hrs.): 11
Dimensions: 6" x 3 7/16" x 4 3/8"
Weight: 8.1 lbs.
Metric Dimensions: 150mm x 87mm x 110mm
Metric Weight: 3.7 kg
Polarity:  Acid
Volume: N/A
Charging Current (Amps.): 1.1
C.C.A.: 210
YTZ14S
Voltage: 12
Capacity (Amp. Hrs.): 11.2
Weight: 8.6 lbs.
Metric Weight: 3.9 kg
Polarity:  Acid
Volume: N/A
C.C.A.: 230
Thoughts?  Recommendations on online retailers?  My local shop wanted $131 plus tax !!
Spec-wise, it doesn't matter so much with the 6th gens.
5th gen and earlier used the YTX12-BS, which was only about 180 CCA and was an inch higher, to boot.
The 6th gen YTZ-12S batteries are much closer to the YTZ-14S (210 vs. 230 CCA) and are the same size.
The bigger issue might be availability.
I got my YTZ-14S at tucmoto.com last June for $104 plus shipping. The shipping cost sucked (shipping to Hawaii), but that's not their fault.
They still list it at the same price, but don't list the YTZ-12S.
motorcyclebatteriesusa.com lists the YTZ-12S for $104.75 and the YTZ-14S for $101.75 with free shipping in the lower 48.
Given the extra 20 CCA for 3 dollars less, I'd go with the 14.
Whoever you end up buying it from, do yourself a favor and avoid any brand other than Yuasa or Wiseco.
What's the difference with the YTX-12-BS made by Yuasa?  Motorcycle Pro Shop lists it as the one for the 6th Gen, selling it for $55 plus shipping.
See link http://www.motorcycl...uct_id=YTX12-BS
Did I get an inferior variation? :unsure:
~Fred
~Fred
YTX-12BS is a sealed lead-acid battery. It's maintenance free, but the YTZ series is the AGM type.
Get the YTZ-14S every time.
More Zolts, less filling!  http://www.vfrdiscus...tyle_emoticons/default/smile.gif
Thanks for the info.  Just ordered the Yuasa ytz14S for $101.99 with free shipping.
I just took another 2% OFF  using this coupon code  MBUSA545
$ 99.71  woo hoo!!!!
Well after placing the order....they gave me another code for 5% OFF.        MBUSA007
Hope someone will benefit from this.
Cheers!
Here's the battery I got for my 2004 ABS VFR. Power Source Power Sport 12 Volt Battery (WPZ12S) 250 CCA, $82.95 It's the most CCA you can get...that I have found anyway.
Get it at:  E-Batteries.com
Cheers!
Thanks, I just did.  Appreciate that, came at a great time.
So what is the best batt for the 5th gen?
Exact same one that's in this thread. YTZ-14S AGM type.
Only it's 3/4" shorter than a YTX-12BS, so you need to fabricate a 3/4" plywood spacer to sit underneath the battery.
I used the bottom of the old battery as a template, tracing a line around the base with a pencil, making sure the line was slightly smaller than the case.
Jigsaw out, sand the edges, and Bob's your Uncle! Instant spacer!
LxW is identical, as is the polarity.
Anyone tried this battery from Batteries Plus?
Not to spendy
Looks like it would work too. No experience with the brand though. I went genuine Yuasa.
Thanks so much for the great info.
Thanks for all this info, guys.
After 25,000 miles and 4 years my battery finally bit it this a.m. It's been teasing with weak starts for about a month.
Dealership wants $148 :huh: for a replacement and I was dreading having to shell that out. Glad to see there are options.
Any feedback on these online no-name options?
Brian.....long time since I last saw you here. Now fire that thing up and join us for a ride!!
Not to spendy
I have one in my 03 VFR and am very happy with it.
New YTZ12S batteries are $310 (AUD) where I live - and that's not from Honda.
Definately get the YTZ14S if you can find it, higher CCA for the same application means that the electrode packing tends to last longer, which means longer battery life.
Well... looks like my battery bit the bullet. I haven't ridden for a few weeks and my bike has been sitting through some cold weather. Last night I turned on the key, everything was fine. Dash came on, fuel pump came on, headlights came on. But when I hit the starter NOTHING happened. It didn't even try to start. I put it on a 2 amp charge overnight. Everything seemed fine...but this morning the on the charger the red 'fault' light was lit. So, I restarted the charger at 6 amps, and a few minutes later it indicated a full charge. Uh, ok. Put the battery back in just for kicks and it did the same as last night when I tried to start it.
Looks like I'll be shelling out bucks for a new battery. Haven't decided whether to go with Yuasa or a cheaper one. The YTZ12S is $113 at my local speed shop. I can get a cheaper one, but not sure if I want to do that. The YTZ14S sounds like a better battery, so maybe I'll just get that one. Guess I can't complain too much, as I'm replacing the original, 4 year old battery.
About 6 months ago I bought a YTZ14-S from http://motorcyclebatteriesusa.com, and it's the same size as the original Yuasa battery. Just checked and the MBUSA007 coupon is no longer valid...all I found was MBUSA545 which gets you 2% off. Interestingly the YTZ14S is 2 bucks less than the YTZ12S.
Just ordered the YUASA YTZ14S at BikeBandit.com for $71 plus $9 shipping. The YTZ12S lasted a good long time. At least 3 years. Thought I'd try this one since I'm using more acc. power these days.
I had meant to post this a while back, but I found out something that makes the YTZ14S less of a good deal than the YTZ12S.
My last 2 batteries have been YTZ14S, and they've not lasted as long as I would have expected. In fact, the last one died after being on the bike for less than a year.
I asked an acquaintance of mine who owns a battery shop how it is that the 14S, although smaller, makes more CCA's.
The answer is thinner lead plates.
The downside of this is that the thinner plates will be more prone to sulfation and shorter life.
That has cured me of the use of a YTZ14S.
The ytz 14s ? Dude what are you talking about, did you buy some fake ytz14 s , these batteries are the best I have 40,0000 miles on mine , its been flawless , far better than original battery.
I dont know what happened in your case, but what your saying is simply not true, this battery is built for st 1300's . And you think its going to fail early in a vfr. That simply makes no sense
Bull crap IM running it, its an Outstanding Battery , mine is over 2 years old and 40,000 mile , still flawless
and not only more CCA , but more reserve Power, meaning it can sustain longer
BTW the ytz 14 is not smaller than the 12 ytz, they are identical in size, which leads me to think, your dealing with some kind of fake stuff. The competive type batteries tend to be mis sized in comparison
my genuine Yuasa YTZ-14s has been in the bike so long, I've forgotten when it was installed.
and still working fine as of this season. It's resting comfortably on the tender as we speak......
For a YTZ14s that is an oustanding price(actually too cheap), normally its a Post $100 battery at most online places . They are giving it away, maybe there's a shelf life or something.
I was about to order the YUASA YTZ14S when i came over this test in the German Motorrad magazine:
01/2007
"MOTORRAD NEWS" verdict: 10 out of a possible 10 for the cold start and load test!
Test verdict from "Motorrad News":
"The strengths of the Delo battery are top marks in our test and an acceptable price. But this battery too needs care and attention in the winter, and can react to neglect by refusing to work. It has been awarded our Best Buy recommendation for its great performance."
A total of nine starter batteries that fit in the standard battery compartment of many BMW bikes such as the K 1100 RS or R 1150 GS were tested (including Varta, Yuasa, Odyssey, Exide, AWS).
TEST PROCEDURE: "To make sure that the nine candidates all started in the same condition, we first connected them to an intelligent charger (Saito ProCharger, suitable for gel and acid batteries) for eight hours. The heavy duty units were then left to settle down overnight. The reason for this is that shortly after they have been charged, batteries exhibit what is known as a hybrid voltage. This is significantly higher than the true battery voltage, but means very little, and it must first be allowed to dissipate. After this resting period, their cold starting current was then recorded using a special instrument (Bosch BAT 121) according to European standard methods - our first measurement.
After another 24 hour break, the pressure was applied again: For the load test we connected a device consuming 300 W (heating mats) to each battery, and measured the voltage after 15 and 30 minutes in order to see the reaction to the discharge process. After being subjected to this harsh treatment, the batteries were then connected to the charger again, and the voltage measured after 15 and 30 minutes of charging. These values indicate how quickly the battery can ideally recover after heavy use."
I ordered this instead. Seems like a good product, but the price in Europe is 50 % higher than the US prices for the Yuasa. In Norway the Yuasa is almost 50% higher than the Delo AMG.
DELO AGM starter battery
I've had good luck so far with my Wal-Mart AGM battery. It's made by Yuasa. Believe it was under $60.00 with a core. Got it there because I was in a hurry and needed one right away.
Holy cow, Capt. Bob, you must've had a whopping coupon or something. Bike Bandit currently lists the YTZ14S @ $179.96 + shipping. Way to score, man!
They are, in fact, both valve-regulated lead acid ("maintenance free") AGM batteries! The only technology difference is that the YTZ series are "factory activated", and the YTX series are purchaser-activated (you add the acid and charge).
Without cutting one of each open, I cannot explain why the YTZ12S and the YTZ14S have different capacities/CCA and the same physical size. But I do see that the 14S weighs 0.5lbs more than the 12S...
Speaking of tests (re the Delo), someone on the "Intruder" forum did a similar kind of battery test, which makes for interesting reading (even if he inexplicably did not test an OEM or Yuasa battery!). One of the best performing batteries in that test was the distinctive yellow Motobatt, which is widely available in the 'States. Might be worth checking out. However, I only use OEM Yuasas...
Picked up A Yuasa YTZ-14s for 93.00 dollars!!!! Delivered to me too!
Who'd you order from?
Has anyone tried the Adventure Power UTZ14S? It's rated at 12V, 11.2Ah, 134 Whr.
Product Dimensions: 6 x 3.5 x 4.5 inches ; 7.9 pounds
Found one on Amazon today for $56.59. Very tempting...
http://www.amazon.co...27&sr=8-1-fkmr1
Seems like the price of the YUASA YTZ14S has gone up since this thread last took place. Checking around the web, I'm looking at several vendors on eBay selling it for $137.99 + Free shipping for this battery. Has anyone considered swapping over to Lithium battery?
http://www.batteryst...X18A1-BS12.html
Well, no one has ever accused me of being a patient man. I ordered the Shorai LFX14A1-BS12 from Motomummy.com. Paid $139.95, free shipping. I figured for about $2 more, the Lithium ion battery's lighter weight is worth it. Will post updates when I receive the battery and install it.
https://www.motomumm...productid=18829
It also has more reserve power in addition to cca, I have 46,000 miles on my yuasa 14ytz, and its been flawless , the orginal 12 Fukarama(oem), got really weak around 42,000 miles.
Your the only one Ive seen have bad luck with these batteries(yuasa, and I suspect either your not running the real thing, or somethins defintely up in your case.
Too many riding the yuasa 14 ytz ,
Just order one from Motomummy.com
$90.00 to the door ..................
Is that the right size battery? It looks like it might be the one comparable to a YTX-7BS (quite a bit less powerful than OEM). Still, these Shorais are starting to look very tempting...
Relax, 'Dude'!
Too much coffee?
Chalk it up to lack of attention to detail: I meant the original spec battery, the YTX12-BS.
The YTX12-BS is about 3/4" higher than the YTZ14S.
As to it being "fake", I don't remember if the two short-lived batteries were branded Yuasa or not.
The rest of the statement is comparative: A battery with thinner plates be more prone to sulfation and shorter life than one with thicker plates.
Can't argue with chemistry.
DUDE , I went to Dairy Queen , a small vanilla cone $1.75 ,, Thats riduculous, no more ice cream cones, Im not paying that.
End of thread · 40 posts recovered Wayback Machine snapshot 7 Sep 2013
