#1 Thread starter
I printed out the 'how to' guide in the maintenance section. I did the clutch bleed w/ no problems.
Moving on to the brakes, I ran into a couple of issues;
1) The guide states that there is only one brake bleeder on the right caliber, however on my '98 (5th gen) non-ABS there are two bleeders on both the left & right claibers. Do I do both top bleeders & then button up the master cyclinder?
2) Where is the proportining valve located? It is not under the seat area anywhere. There is a metal cyclinder w/ brake lines attached on the right side located close to the fork leg. It has no bleeders on it.
3) Is the sequence for bleeding the rear caliber the same as the fronts? That is, bleed the top (front) valve first and then the center valve.
4) Do all of the circuits activated by the proportioning valve (the center bleeder on each caliber?) get their fluid from the rear master cylinder?
Thanks for any help. I don't want to screw up the brakes!!!
(I am posting this both in the 5th Gen area and in the Maintenance area.)
