Lascar Voltmeter Install Pics
1 posts Started 25 Jul 2007 Last recovered post 25 Jul 2007 Wayback Machine snapshot 21 Sep 2010
I put this in Electrics because I think a voltmeter should be a mandatory VFR electrical item - for your sanity!. For about the cost of 2 tanks of gas your can do it too!
Here is my Lascar Voltmeter install. Just thought I would show everyone since I had been holding off on this *ESSENTIAL* VFR farkel trying to settle on a location for it. Not having a voltmeter bit me yesterday when my battery packed it in while trying to get to work! This little sucker would have told me exactly what was going on.
http://www.vfrdiscussion.com/forum/uploads/1185263231/gallery_11167_3227_41908.jpg
Drivers View
I was going to drill a hole to mount the voltmeter but I really like the factory look of my bike and I don't like messing it up permanently. Don't get me wrong, I'll drill for frame sliders to protect $1000 worth of plastic but I don't like slapping stuff all over. That said I don't like "Mickey-Mouse" fixes or repairs either so I was having trouble figuring out how I was going to handle this mandatory little item.
The permanent mounting locations would have been on the dash or on the fairing. The dash option seemed way too stick-on "Canadian Tire" (Canadians will understand this). I almost stuck it on the flat upper of the fairing but I have had those fairing on and off so many #$%& times that it would have been pain to disconnect the wiring each time the plastic was flying.
So I came up with the following solution. It is secure, removable, and best of all puts the voltmeter in a nice central, fairly visible, location.
You will need:
  • 3 inches of 3/4" steel strapping (about $4 at the hardware store - in the plumbing section), and
  • a Lascar 1200 Voltmeter (I got mine from Allied Electronics for $30 USD).
Simply mount the meter to the strapping using one of the handy, ready drilled, holes then pull one tank bolt and put it through the other end of the strapping. Tighten the tank bolt back up and bend the strapping with the meter into place. Route your wires - my positive wire goes to my R/R wire mod and I put an open ring terminal on the ground and slipped it under the R/R bolt. The tank bolt or the metal strapping would also work as a ground. I put a little shrink tubing over the wires to protect them and make them look a little more factory and routed them nicely alongside the others.
DONE!
The only drawback of this location is that it is not protect from rain (like it would be if it was on the dash). The instructions say its "splashproof" and I don't think it would get wet while riding but it will if your bike is sitting out in the rain.
http://www.vfrdiscussion.com/forum/uploads/1185263231/gallery_11167_3227_7230.jpg
Side View
http://www.vfrdiscussion.com/forum/uploads/1185263231/gallery_11167_3227_21964.jpg
Instruction Pic
This may be a little "Mickey-Mouse" for some and I'm sure I could come up with something better than the strapping but you have to get down and look hard to see it. If I want under the tank I simply bend it out of the way and get to work. You could probably flex the strapping back and forth a couple dozen times before your broke it - big deal it's about 2 cents worth of strapping. The steel will likely rust so you could put something on it or use different strapping - the back of the box says it comes in Galvanized, Copper and Nylon Coated - take your pick.
http://www.vfrdiscussion.com/forum/uploads/1185572379/gallery_11167_3051_55923.jpg
Super cheap mounting stuff - next best thing to binder twine and bailing wire!
On the techy side this meter has a VERY fast refresh rate. The specs say 3 samples per second - so it is constantly flickering away (it's almost a bit too distracting to be on the dash I think). My setup is hot-wired so I can read it at any time - it draws 3mA.
BTW - It's a nice looking meter that matches the aluminum of the bike quite well. Too bad Honda didn't build a voltmeter into the left or right gauge panels. Then again maybe it's just as well, it probably would have shorted out, taken out the whole dash, and started a fire! :o
End of thread · 1 posts recovered Wayback Machine snapshot 21 Sep 2010
