Aftermarket Radiator Fans
5 posts Started 5 Oct 2007 Last recovered post 17 Oct 2007 Wayback Machine snapshot 7 Jul 2017
Hi Everyone
My old warped OEM radiator fans way past their replacement.
I've been thinking of getting aluminium ones instead of going back to stock. Only brand I have in mind is Muzzy and they don't seem to stock for the Vtec.
http://www.muzzys.com/fans.cfm
Anyone know an alternative brand? Thanks in advance
Looked up the part number = 19020-MCW-D01
Tried to cross-reference it to other Honda models.
Looks like it fits the VFR800s and the Valkryie Rune and that's it.
Unf, none of those models are on the Muzzy's list. Sorry.
Looks like you'll have to buy another stocker.
Or fabricate to make something else fit.
A pair of R6 fans fitted perfectly on my 4th Gen radiator, and their combined weight is similar to the big OEM fan.
Fans are one of those parts that sometimes differ from one another only by the mounting brackets. Different mounting bracket=different Honda part number, but the fan motor is often the same. Unfortunately, the only way to know for sure is to have access to a bunch of different OEM fans, or know that someone else has swapped a particular one for another. Can't help you there, sorry!
If its just the fan, the motor might burn out since it weighs more than the plastic.
Also if the blades ever touch the rad, you're probably gonna have a nice hole in it.
End of thread · 5 posts recovered Wayback Machine snapshot 7 Jul 2017
