Ok. Its not that cold, but its hanging around the 50's in the morning and my '01 will not reach 160F on the highway and has been as low as 141F. I'm afraid the engine isnt able to fully warm up and its gonna get worn out or use way too much fuel.
I want to cover the rad without the fan. Just incase it does get hot, the fan is still able to cool that rad.
Anybody have a clue on what to use that can easily be put on and taken off?
I think I'd be checking my thermostat before bothering to cover the radiators. If the cooling system is operating properly, you should be fine to well below freezing temperatures.
hlfI think I'd be checking my thermostat before bothering to cover the radiators. If the cooling system is operating properly, you should be fine to well below freezing temperatures.
Temp does just fine in 60 and up weather. It has no problem reaching 200 in the city.
Even though you don't have the notorious '02 --- I'm with hlf --- you have a stuck thermostat. Mine showed the same symptoms. Then I fixed it and now my bike will hold at 170 *f even when the air temp is below freezing. No cardboard needed.
Thermostat is sticking open, circulating coolant to both radiators when it is only supposed to circulate to the right radiator under 170f.
To test for sure, start the bike up and put your hand on the left rad when coolant temp is at 150. The left rad should be cold until 170. Miguel (HispanicSlammer) has a great write up on the procedure in the how to section. It is a bit of a PITA and you need a 18+ inch long #2 phillips screw driver.
Even on single digit days my 06 always warmed up well and plenty fast...............staying cooler was the usual problem I had. Warmest running bike I've ever owned.............. +1.gif
should you wish to cover the radiator, they make cool zip-tie type things for adding fans to radiators...the stick through the fins and attach to a pad on the back...might be just what you need.
Like what was said (change your thermostat) until its 10 degrees or below you shouldnt even need to think of covering your radiator, its about the same for running hot too, if it isnt 120+ there shouldnt be any reason to alter your cooling system which would indicate a problem.. I drive a truck which have 12 gallon capacity for coolant, we cover our radiators more to keep warm when sitting and idling, not because there is a problem with it heating going down the hiway..
somebody has been watching to much ICE ROAD TRUCKERS :thumbsup:
jeremy556Thermostat is sticking open, circulating coolant to both radiators when it is only supposed to circulate to the right radiator under 170f.
I'm up in New Hampshire and ride my bike regularly through the cold weather and have never expereienced a problem getting the bike above 170 degrees. The coldest temps I've ridden in were -10 degree. The water pump in my car at the time froze and was in the shop. I sure got some strange looks from people when I pulled inot work. Even at that temp, I did not have a problem.... temp rose above 170 degrees after a proper warm up. Probably fell into the 160's while going down the highway.
My 4th Gen never gets to operating temp if it isn't over 80 out. I've checked the old t-stat in a pan and it worked fine, but replaced it anyway. Still the same. I cover my rad with a vinyl cover during the colder months to get to temp.
Is this topic still alive?? Put the cardboard on both sides of the rad that way you can decorate it with different colored crayons or marker, Even draw you a turbo in there some where and make loud whooshing noises.. :goofy: :offtopic: :goofy: +1.gif
End of thread · 25 posts recoveredWayback Machine snapshot 7 Jul 2017
