Long Awaited Fix
12 posts Started 4 Nov 2007 Last recovered post 16 Nov 2007 Wayback Machine snapshot 24 Jan 2008
Well, as some may know and most probably don't my bike quit running earlier this season. Sometime in early May was the last time I've been on a bike. It started with a TP sensor error. After trying 3 other USED trottle bodies I decided it was something else, plus it wouldn't ever start after I took the orginal set off. Well I was talking wiht a buddy a week ago who I hadn't talked with in a year probably and he said let's give it a good try before you take it too Honda, plus the Honda mechanic told me after hours to check fuel pump pressure before I give. So tonight was the night. It was giving a TP code, Ignition pulse code, and a cam sensor code. We put the meter to work on the Ignition and cam sensor, they tested out fine. He brought over a set of injector pulse testers and we found that we didn't have any injector spark or spark plug spark. We checked all the grounds that we could find as we went!!! About the time we were going to give up we decided we'ld try the other ecu that I had bought USED from a board member. With a little bit of luck, we "accidently" left the key on and kill swicth on. As soon as he moved the computer the fuel pump reprimed itself as though you shut the key off and turned back on again... "hmmm,, that's wierd" we both said about the same time. So with continue playing with the harness on each side of the ECU and each plug. The pump would reprime and reprime. We had a spark plug setting on top of the head grounding out which would spark when moving wires. As we kept wiggling, trying to figure out which wires were shorted we noticed that it was firing on a random cyclinder from time to time. Making a firing sound. Put the plug back in the got it to start when hold the ecu right but the #2 header pipe didnt' warm up at all.... We stripped all of the harness all the way back to the main part of the twin spar frame, nothing. Plug the otehr computer in and the same things were happening. So get to looking at the plugs of the harness at the ECU. The black connector had square gaps as where the grey harness had rectangle gaps. Remove one wire at a time and make the connection a sqaure again. Problem fixed. No more codes and running like a champ again in November in Nebraska. I'm super excited and also pissed!!! I spent a couple of hundred on parts that are now going to eBay and here plus lost out on a full season of great weather!!! I bet I will be on it within the next week 40* and windy or not!!!! I blame the problem on the pc2 that apparently has pins that are a bit larger than the factory pins, at least I think. The wreck 2 years ago could have contibuted a little as well though. Moral: Don't over think things, don't miss the obvious, and try the easy/cheap things first!!! Oh well, it's goin' again at least.
been there. had trouble with my first 3000gt. rebuilt the upper part of the engine twice before we realized it was a bad pvc valve.
great news that you are running. i remember when you first posted about this as i was shocked at the cost of a new throttle body and the need to by one to fix a sensor! what an obscure problem. i hate issues like this that really make very little sense. anyways, glad you are riding again!
I guess that if I should ever need a TB set or an ECU I'll have one waiting now is the only good thing about it.
Went out today to put fairing all back on and go for the last(only) ride of the season as it was 75* out. I figured I'ld better try to start it before getting plastics all on to find out it wouldn't start. Good thing too. It was a no go. I looked over everything that I'ld played with in the last 3-5 months and it looked fine. The terminals mentioned above looked like they should be making contact but I bent them a little tighter just in case. Grabed a spare spark plug to ground out and check spark, got it. Well maybe, just maybe we'ld fouled a couple of plugs fooling with it. All four plugs were soaked. Put the spare set I always have (around here they are special order unless you pay $5.39 per plug at Honda for NGK). Ran great and still managed to get in a couple of hours seat time before I pussed out as it was getting pretty cold (50s). Thanks to all who helped, gave advice ro loaned me parts.
glad you were able to take it out after all that work. congrats on figuring it out, too.
Cool. Maybe the weather will give you a break and you can get a few more rides in yet. smile.gif
yay is right! i remember many emails and a loaned throttle body. sure glad it worked out for you. had it been mine, after about the second week, i would have been riding something else.............................. wheel.gif
Congrats on up-and-going again...... fing02.gif Man, that took some real patience......... blink.gif
Flyer-- Thanks again for the loan of the TB set. Also this definately counts out that set being bad as well. Anyhow, thanks alot.
Took the bike out tonight again. Much to my surprise, I got pulled over in a 45mph zone doing like 40-ish. I pull over and he tells me my tags are up, as is my insurance!! Ticket time... To make the thing worse, I just applied with the local PD, same department that the tickt came from. Hopefully this doesn't count me out completely. I just didn't give it any thought as I wasn't riding it for the last 6 months. Rod eit last in March and plates were up in April... Oh well, hopefully I can get ins. and plates on it and the judge will drop it with an explanation. If not, well I deserve it I suppose.
hawglet, Nov 16 2007, 05:54 PMFlyer-- Thanks again for the loan of the TB set. Also this definately counts out that set being bad as well. Anyhow, thanks alot.
as the saying goes...........if you weren't having bad luck........you wouldn't be having any at all....................get the ins and regis and the judge may appreciate your story and let you go........maybe not, but try!
as for your app to the local pd........good luck, this won't have any effect, unless its one of many! rolleyes.gif
End of thread · 12 posts recovered Wayback Machine snapshot 24 Jan 2008
