Hi all,
I recently went about giving my VFR 800 Fi (2000 reg) a clean up and since removing the farings etc when I go to start the bike there is no longer a whirring noise from the fuel pump when the ignition is turned on, consequently the bike will not start. I am really stumped as to what it could be, I've checked for loose wiring around the bike and checked for blown fuses in the fuse box but all seem to be fine. I can't understand why it is doing this as everything was put back exactly how it was beforehand.
Hi all, I recently went about giving my VFR 800 Fi (2000 reg) a clean up and since removing the farings etc when I go to start the bike there is no longer a whirring noise from the fuel pump when the ignition is turned on, consequently the bike will not start. I am really stumped as to what it could be, I've checked for loose wiring around the bike and checked for blown fuses in the fuse box but all seem to be fine. I can't understand why it is doing this as everything was put back exactly how it was beforehand.
Anybody got any ideas?
Cheers.
Please make sure that the large orange kill switch thats adjacent to the throttle is switched to "RUN". Ask me how I know this :goofy: It should start right up now that it isnt in kill switch mode.
Hello Dino, Sorry I should of mentioned that I had made sure that the kill switch was in the correct position before posting here. http://www.vfrdiscus...tyle_emoticons/default/smile.gif
Unforunately no closer to finding out the problem, I'm really at a loss as to the problem, such a pain and I'd almost finished putting everything back together. http://www.vfrdiscus...tyle_emoticons/default/sad.gif
Hello there,
Thanks for the reponse. The engine is cranking over but not firing, so I assume from this that the kill switch and the side stand switch are okay? The fuel pump is not making a noise so it is not getting power for some reason, hence why the bike wont start.
What is most strange is that before cleaning the bike, it was all working perfectly!
Hello there, Thanks for the reponse. The engine is cranking over but not firing, so I assume from this that the kill switch and the side stand switch are okay? The fuel pump is not making a noise so it is not getting power for some reason, hence why the bike wont start.
Okay I've just got a test meter on the little brown connector (branches off with a blue connector for the fuel sensor) that powers the fuel injector and there is no juice coming out of it when I switch the ignition on, so it seems the fuel injector is not getting any power at all! http://www.vfrdiscus...tyle_emoticons/default/sad.gif I've had a look at all the cables in the surrounding area and checked the fuses again but I can't see any problems at all.
Lift the tank and check for battery voltage at the fuel pump connector, if there is no voltage there are 3 fuses in line, the main 30amp (probably not since you get everything else) then a 10amp, and a 20 amp in the fuse box. after that check the connectors for the engine stop switch, fuel cut relay, engine stop relay, and the bank angle sensor, then the last thing is to reseat the ecm connectors- clean and treat with diaelectic grease all the connectors.
fuel cut relay is located on the sub frame by the seat on the right side, enngie stop relay is on the same side further forward by the rear brake fluid vessal, bank angle sensor is behind the headlights up front and in the middle of the bike. You can probably figure out which one it was by where you where cleaning!
I've been searching the boards for the solution to the exact same problem. In my case, I changed the battery on my '99 a few months ago, took it for a quick ride, and parked it in my garage (on a float charger) until last weekend. I know, too long w/out riding.
Now, when I try to fire it up I get exactly the same symptoms -- no whirring of the fuel pump when I turn the key, turns over great, won't start... I've confirmed that there's no voltage to the fuel pump by testing w/ a volt meter, and checked the fuses, the stop relay, and the fuel relay. I've yet to test the bank angle sensor, the ECM, the input power line to the ECU, or for an open/short circuit in the engine stop switch ground wire. Honestly, I'm dreading removing all the bodywork to get to the bank angle sensor, and I don't really know how to test the ECM, or how to look for the other two electrical issues.
From rebuilding my bike I know that it's really easy to put the sensors that sit on the battery case back incorrectly (don't ask how I know...) and only by using the shop manual diagrams - my clymer's wasn't detailed enough - was I able to get it back together and have no issues with the fuel pump.
Thats a pretty sure sign of water issue, in a connection
Just an idea...
Thanks, DotW. I think you're talking about the fuel cut and engine stop relays, and I removed and tested both of them, but no luck. Next I suppose I'll unplug and reseat the ECM. If that doesn't work, I'll pull things apart and try the bank angle switch (though it seems odd that it'd just fail while sitting peacefully in my garage). If neither of those work, I'm not sure what I'll try...
Any advice on how to test (or bypass) the handlebar kill switch?
a paperclip will work....................................................................................................................................................................................................................................................................................................................................................
....................................after you get to the connections.
Failure of the fuel pump to cycle is the exact problem I've been having with my '04. A couple friends and I narrowed it down to this issue last Friday night in my garage. We disconnected and reconnected a couple switches and fuses and checked for any loose wires around the bike. Since then the fuel pump has cycled every time and the bike has started right up. It's frustrating not knowing exactly what caused the problem, or if it will reappear.
If the issue reappears - and we figure out exactly what's causing it - I'll post up the solution here.
Thanks, Tim. I'm encouraged that someone's been able to get their fuel pump to work again http://www.vfrdiscus...tyle_emoticons/default/wink.gif
Tonight I further dismantled my bike and tried:
1) unplugging the ECM, removing my Power Commander (to eliminate one more possible point of failure), cleaning and applying dialectic grease. Still, no fuel pump.
2) testing the bank angle sensor (per instructions in the shop manual). Seems to pass the voltage tests, and I can hear the relay "click" when I turn the ignition key on and off. Still, no fuel pump.
3) unplugged the side stand switch and bypassed it with a paperclip. Still, no fuel pump.
Any advice on how to get to the handlebar kill switch connections so that I can try to test and/or bypass?
Any other switches or wires or connections anyone suggests I look at?
mine was the fuel relay, and an unplugged ignition coil. Thats right, if you lose a certain coil, you lose fuel. At least thats how my 4th gen is wired. Look through the diagram and trace the wires as far as you can, using a meter to check for proper voltage and connectivity. I used a bit of wire to jump out the relay, but still have the relay connected so my coil will work. Its a mess. Anyways, the schematic is your best friend right now.
One of the connections we looked at (per a tip from Kanadian Ken) was the starter relay switch. I don't know about the 5th gen. VFR, but on my 6th gen. it's right behind the battery. Unplug it and check for dirt, etc. Also pull out and check the fuse (if it's like mine) under the plug itself.
Thanks. I'd tried the starter relay (I believe the '98-2000 manual calls it the "engine stop relay") over the weekend, but tried it again just now. Upon further inspection, the 4P connector looks a bit suspect (slightly melted), but the relay seems to work appropriately. When I turn on the ignition and turn on the kill switch I can hear/feel it engage. On the 5th gen there's no fuse under the relay itself (at least I couldn't find one), instead it lives in the main fuse compartment in front of the battery. Checked all of those again tonight, too.
Also decided to try the fuel cut relay again. I took it out and bypassed it per the manual, but no luck. This relay did pass the voltage test per the manual, but it doesn't make a click when the power's turned on/off. I'm guessing that's appropriate?
Next, I took apart the kill switch control on the handlebar, sprayed the contacts with with contact cleaner and put it back together. No luck there.
Finally, I checked the connections on all of my coils. They all seem tight.
Another day, another donut...
The only other things to try (per the manual) are:
1) Open or short circuit at the input power line of the ECM 2) Faulty ignition switch 3) Faulty ECM 4) Open circuit in the engine stop switch ground wire
I think I can manage checking #2 now that I have all the bodywork off, but I'm probably going to be stumped on #1, #3 and #4...
I went through my harness connectors and found a few with corrosion, cleaned and greased. It has worked every time I've turned the key since yesterday :)
Sent from my iPad using Tapatalk HD
End of thread · 24 posts recoveredWayback Machine snapshot 20 Apr 2016
