[image: View Post]Ryanme17, on Sep 7 2008, 08:40 PM, said:
[image: View Post]Darth Bling, on Sep 5 2008, 04:01 PM, said:
It'll probably be easier and faster to fix the tabs yourself with epoxy or plastic-weld than it would be to wait for the new cowl to come in and then remove the old cowl and install the new one.
Easier and faster? Yes, definitely.
Better? No, I haven't had a single piece of plastic I've epoxy'd back on actually stay for very long. When I got in my accident and the signal got pushed in, breaking that tab totalled the upper cowl.
There's also a bunch of different types of epoxy too. I rebuild a bunch of broken tabs on my headlight housing using epoxy and those fake plastic credit cards you get in the mail. My headlight have been rock solid for the last 2 1/2 years. :rolleyes:
[image: View Post]Ryanme17, on Sep 11 2008, 03:04 PM, said:
[image: View Post]Tightwad, on Sep 8 2008, 12:53 AM, said:
Plastic weld is different from Epoxy...instead of gluing the piece, you are actually melting two pieces into one....similar to how JBweld and welding are different.
Tell me more! Where do I get this stuff?
When I broke the mount for my turn signal, there wasn't enough surface space to rebond it at now matter what you use, because it broke right at a seam.
I know you can find a plastic welding kit at
Harbor Freight.
