I drove down to Maryland on Friday and traded my 85 700F and an 83 750F rolling chassis to Timmy for his 22,000 mile 86 VFR700 and a set of F2 forks with trees. I have a LOT of great(and some not so great) memories of my 700, but its future was not too bright at my place now that I'm restoring the 750, so... time to move on.
The 86 is a bit rough. It was laid down on at least one side, the upper stay & subframe are pretty bent, but the frame looks nice as does the swingarm. On the upside, it came with a Fox twin clicker, a K&N filter, Factory jet kit, and a 4-2-1 Yosh pipe.
I decided I'm going to go completely against the grain with this bike, if you were hoping "oh Seb's gonna make a nice tastefully modded 86 and do it justice", think again.
My current thoughts are, but are not limited to:
Bodywork:
-A Kawasaki 636 racing upper, bottom shaped a bit with no lower fairing, one 636 headlight, a VTEC tank(maybe, might be too big), and Ducati 1098 tail(trying for a stock tail, but they are pricey, might just get race parts). I'll be building an all-new subframe from aluminum to support a solo tail. This will be a no-passenger bike.
Here's a really rough and lame attempt at a rendering using MS Paint(don't laugh too hard Dutch!) (and no, it won't be green!)
Suspension:
In the front, I will use the F2 forks(they are 1994 forks with cartridge internals!), but I'm unsure yet if I'll use an F2 or F3 wheel. originally I was thinking of 636 forks or other USD forks, but then Tim & I came across the F2 forks at his brother's shop and the price couldn't be beaten... Wheels, I wanted 636 wheels... not sure if that will work in the F2 fork... probly not. I would like the floating rotors of the F3 and could care less about the speedo drive, I really don't like the boxy RC26 gauges anyway. I'll use a Veypor/Vapor/Koso/Acewell gauge set either way.
In the rear - more options. I need to tear the bike down a bit more before I can make a call on the swingarm swap, but I have a spare CBR600F4i swingarm here, apparently someone has fitted one on a second gen once before - so it can be done! I have fitted a 2004 600RR swingarm to my F4i, so I know that if the F4i fits, so will the RR unit... oh, the possibilities!
Proof:
Third option is to brace the stock swingarm a la Chuck Crites. Just can't leave it stock! :biggrin: Bonus staying stock is that I get to keep the Fox shock in there... I have a 900RR rear wheel that will fit a 180 tire, going to try fitting it with a VF500 hub real soon.
Motor:
... will stay as-is, already has been jetted, so, just clean it up/repaint the case and valve covers, a little S100 and a carb clean, she'll be good to go.
Exhaust:
Already has what looks like a full Yoshimura system, I'm just going to stretch it up under the tail and weld up an exhaust out of sheetmetal. I kinda like the exhausts that Competition Werkes makes for some new bikes, they look and sound different.
My challenge will be maiking a shape that looks right with the 1098 tail. If I'm lucky, I'll get to build it out of titanium(the can part). Another option is a pair of '08 ZX10R cans that Timmy also sent home with me... positioned closely together, they've got some potential!
They're aluminum and titanium, pretty light, especially after I gut them out and install some perfed cores to get real sound out of them.
Other stuff:
Going to to a lot of misc stuff - cleaning, polishing, painting, etc, and also going through all the maintenance with coolant, fork seals and oil, engine oil, brake fluid. I'll probably add some newer switch pods from a different bike and newer master cylinders.
I got so excited when I got the bike home that I didn't take a before pic, so here's one Timmy sent me:
Here it is as of right now:
So many projects, so little time! :blush:
ANY comments and feedback is welcome, the last words I want to throw out there against the "paint it RW&B with stock bodywork" guys are - light weight. That stock subframe is huge, and kinda heavy! The big plastic mudguard/fender thing is pretty heavy also. Between the new subframe, exhaust, and wheels, we're already talking a substantial savings in the right places. Get rid of the weight of the stock bodywork and a bunch of miscellaneous stuff, well, you get the idea. Fuuun stuff!
:cool:
