Cool Voltmeter Alternative
51 posts Started 20 Nov 2008 Last recovered post 7 Oct 2011 Wayback Machine snapshot 18 Sep 2021
A number of riders here use Volt Meters (Datel being the preferred unit). There are also a large number of riders who use a Signal Dynamics LED that indicates charging status. Both options are good, and 100% up to the owner as to which they like. In the search for a good meter to supply, I came across this updated version of the Signal Dynamics indicator. http://www.lascarelectronics.com/pdf-usb-d...01196093175.pdf http://www.martelmeters.com/img/products/FPSI-1010-1_large.gif This meter can be custom set for low/norm/high charging voltage, as well as set to either blink the charging status (to save battery) or to show it constant. In addition, it can trigger an alarm when the voltage is outside of the "Green" range. It would be possible to use this as a safety valve to shut down your auxiliary fuse panel in the event of a loss of charging! I thought it was cool, but I am a nerd. *edit* for those who don't feel like reading the Datasheet linked, it measures .5" x .5" on the hole, so still quite small. It requires "programming" so it wouldn't work just out of the box. Quote Ok, I promised a review so here goes.... I ordered 2 of the Charging Status Indicators. They arrived rather promptly, which is to be hoped for when shipping is much too high. I ordered two to defray the shipping cost, figuring there would be at least two people who could use one. http://img241.imageshack.us/img241/9455/chargingstatusindicatorve9.jpg The box when received is woefully oversized, given the indicator itself measures a paltry .59 x .59 x .8 inches. I was actually worried I would drop it and lose it... The instructions are in more languages than I can recognize, but the first is English so I was able to proceed. http://img367.imageshack.us/img367/1008/chargingstatusindicatordr0.jpg http://img520.imageshack.us/img520/3765/chargingstatusindicatorld2.jpg Out of the box they are configured to go from red to green at 10 volts, then green to red at 20 volts. This just wouldn't do of course, unless the warning you want is "hey idiot, your battery is dead" or "hey moron, your Regulator isn't regulating and everything is cooked including that really expensive computer". Luckily changing the voltage is very easy, providing you have an adjustable power supply handy, or something that can simulate exactly the voltage you want such as an odd assortment of AA batteries. I happen to have an adjustable power supply (which I built myself) so I was in luck. All it requires is that you set the initial voltage, place the jumper then remove it, then set the next voltage, place the jumper and remove it. Lastly, if you want it to blink the status insteady of a steady light, you change the voltage by 1.4 volts or more, then place and remove the jumper one more time. I opted NOT to do this on the testing as blinking lights would be annoying while I ride, and others probably feel the same. The blinking option is included for battery saving purposes mainly anyway, and if an LED is the go-no go on my battery the thing is already shot. Wiring the Indicator is also very easy. I tried to show the wires connected, but basically it is a power wire, a ground wire, and a sensing wire. You can wire the power and sensing wire together if you want, or you can run the sensing wire to the battery for the best reading, but the power wire to a switched source so the light isn't always on. I prefer to have a switched source with no voltage drop, so I would just connect mine to my auxiliary fuse panel anyway. Small gauge wire is all that is needed or recommended really...I used 18 gauge for my test hookup. http://img241.imageshack.us/img241/838/chargingstatusindicatordw7.jpg http://img367.imageshack.us/img367/2534/chargingstatusindicatorxd6.jpg I shot a short very poor video (using my still camera, hand held, while also balancing a box on my head to block extra light) to demonstrate the functionality. You can see in the Video that the Red goes to Green at 12.6 Volts, and then back to Red and 15 volts. When going down the Red goes to green at 14.5 volts, and back to red at 12.1 volts. I am not really sure why there is a .5 volt differential, but I like it because I would hate to have the thing going from green to red and back too fast. I have two of these available if someone wants one, $40 setup to the voltages of your choice and shipped to your door first class mail. Thanks for reading! Tightwad
That looks like a neat piece. Other than the little bit of programming, the display should be dummy-proof. Green=good Red=bad. I guess they are called idiot lights for a reason.
Tightwad,
Are you going to carry the idiot light and do the programming? If so, how much and is it available from you URL?
Thanks for the update and info.
I don't see anything about it being waterproof?
I highly doubt it is waterproof, please don't drive your bike underwater. However, being an LED, there isn't anything for water to hurt, unless you submerge it.
[image: View Post]VFRcr8zy, on Nov 20 2008, 09:36 AM, said:
Tightwad,
I have considered getting one to review, although I have no need for it (hasn't stopped me in the past...). Price is very set on them, about $29 plus shipping from the supplier. Shipping would be the killer on individual units, so it isn't as attractive as I would wish. I have found the same true for the Datel meters. I would probably charge $40 for this meter if I stocked it, plus shipping as applicable.
Programming would be simple, more than happy to do that for anyone who wanted. It just requires an adjustable powersupply.
[image: View Post]Tightwad, on Nov 20 2008, 11:54 AM, said:
...please don't drive your bike underwater...
Damn.
That was my next project.
But he told me not to I guess I shouldn't :goofy:
For me, reading wiring diagrams is like trying to read Chinese Mandarin. I can do it, but it takes a lot of time and energy. Would this be an easy wiring installation, or a frustrating experience for me? :huh: I would be interested in having one of these just because I can, not because I need it. :biggrin:
Depends...if you want it to just read and go Red-Green-Red then it is 3 wires (2 positive, 1 ground). If you want an audible alarm, or to have it trigger a relay, that requires another circuit. I bet most people could install easily, especially if you have an auxilary fuse panel already to provide an easy spot to get power from.
Want me to demo it? Donate here: https://www.paypal.com/en_US/i/btn/btn_donateCC_LG.gif
Well is it short or long form characters???? (or maybe pinyin) :-)
:biggrin:
Donation made via PayPal.
That's one of the things I like about my Escort 8500 radar detector, it has a mode for the display to read voltage except when it detects radar / laser. It's very acurate and I don't have to add a voltage meter. At least one other radar detect does this also (I think BEL).
ki-speed (Mark)
Considering the possible problems that our generation 6 VFR are having a way of monitoring the voltage might be helpful. I do not have a ground problem and the recall HAS been done on my bike.
I would be interested in this item so long as it fits in the cowl and is plug and play.
My Scorpio alarm was quite simple to wire and I learned a great deal while connecting the FuzeBlock.
A meter would be my next addition.
Brian
ki-speed (Mark)
:biggrin: I bought a voltmeter from Tightwad but it's just collecting dust now that I use my 8500 for voltage. I had the 8500 first, I forgot to RTFM... If anyone needs a voltmeter Pm me, I'm not trying to make a profit on it.
*The voltmeter has been sold*
This is probably a good idea. With all the electric mods all you guys got me wanting, I'm gonna have to have it... another mod added to the list... Thanks! :biggrin:
Thanks for the heads-up on the Escort 8500 voltage meter feature. I have one of these radar detectors and didn't even know it had this feature available. Can't wait to get home and play with it!
I have an older Valentine. Got the wife an Escort (AFTER her ticket :biggrin: ) for her cage. Didn't know it had it either... Might have to swap :huh:
To me I prefer a meter to a simple light, and the extra $20 is worth it. Some prefer the simplicity of a light. I figured this option was cool enough to mention for those who want it. I will order two and do a writeup on it....but I probably won't actually install it as I don't need a second hole in my panel. It will fit quite nicely I think, so that won't be a problem for those looking for some peace of mind.
A note to those using their Radar Detectors, if the Detector is powered through the ignition switch, instead of relayed from the battery, your reading could be a false low, so don't panic before you test on the battery directly to verify.
I think that these changing color LED volt monitors are just a liitle bit too "abbreviated" for some. I think it's good to monitor a trending voltage instead of a pass/fail approach. I'm afraid that if that things changes to a red glow, it might be too late to seek a limp home method before everything fades to black on the bike on the road. JMO
Beck
95 VFR
I use a Dyna Charge Monitor DCM-1 to gauge the health of my charging system. Below is the "blurb" and website. I installed the Dyna on the inside of my left cowling with direct connection to the fuse panel and ground. Two wire only and no programming required. The little gizmo is compact and sealed so I'm assuming waterproof. This summer, at the Nelson Rally, I started to get a low voltage condition (red light on instead of the OK green). The hotter the weather and slower I drove the more red light I got. On the highway at speed (never faster than posted :biggrin: ) the green would return. Once home I started the trouble shooting and found a fried stator. It seems I had a bad connector between the stator and the R/R and it burnt out the stator. All is good now and the happy green light is constantly on. I would recommend this device to all. By the way, the stock connector is long gone with a more positive connector joining the Stator to the R/R. Removing the connector made the routing of the wiring between the cylinders a piece o'cake.
http://www.dynaonlin.../Dyna_Monitors/
Dynatek Charge Monitors
The Dyna Charge Monitor is a valuable addition to vehicles with a battery ignition and a charge system as found on nearly all stock vehicles. The Charge Monitor allows easy determination of the operational state of the charging system with a quick glance at the indicator LED's. The Charge Monitor is housed in the same small rugged case as the Voltage Monitor. The Charge monitor can be used on any vehicle with a 12 volt battery/charge system. The Charge Monitor has three indicator LED's to show the charge status: red, amber, and red. When the right most red LED is on, the battery is being overcharged due to a faulty voltage regulator. When the green LED is on, the battery is being charged at a normal voltage. When the left most red LED is on, the battery voltage is getting very low and the charge circuit or battery is failing.
The small form factor, and clean mounting, plus the options to set an alarm or trigger a relay or what have you is what I like about this item....any bigger and I would want it to give me a live reading like my current one does.
I'm looking for one that gives the actual reading. What model do you have installed on your bike?
Just get the right radar detector and it will have a volt meter built in.
:blush:
bill220
TightwadThe small form factor, and clean mounting, plus the options to set an alarm or trigger a relay or what have you is what I like about this item....any bigger and I would want it to give me a live reading like my current one does.
I personally use one that I built from a couple of components. It requires a 5V power source, so it has a second circuit that is hidden behind the panel. I sold this one for awhile but found it was not worth the effort between a supplier that was flaky and having to assemble/test them. The Datel meters seem to be the best 2 wire alternative, although the Stinger models look pretty good as well. I can still get the Stingers, but demand for them is low enough that I don't keep one on hand usually.
My meter:
[image: Volt_Gauge_001.sized.jpg][image: Volt_Gauge_004.sized.jpg]
Datel Meter:
[image: Bike-Meter-1.jpg]
Stinger Voltmeter:
[image: 1bde_1.JPG]
Ain't nothin' better than a voltmeter to see what is actually goin' on. 30 years of experience in the electronics field leads me to that conclusion.
I'd like to get one of those Stingers, how much? Is the Datel any better?
I'd probably use one strictly for controlling an accessory fusebox. Can any of the other voltmeters do that?
Ijust noticed that AeroStitch has an interesting combo meter-> air temp, volt, batt condition etc. $32 Any one tried this gauge?
5-Function Digital Meter #4632
Detailed Images
Info galore in a compact, digital format that could fit nicely in your bikes’ cockpit. Two thermometers incorporating an ice/freeze alert, a voltage meter, a three-LED battery condition meter, and a combination clock/stopwatch that operates in either 12 or 24 hour formats tells you a lot about your surroundings, the time, and the condition of your charging system. A ‘black ice’ alert flashes when that hazardous road condition threatens. Temperature minimums and maximums can be stored in memory and cleared easily. Not extreme weatherproof without custom modification (disassemble, apply silicone sealant, reassemble) 5.5"×1"×.75".
http://www.aerostich.com/product.php?produ...=601&page=1
I saw an LCD one on a couple of bikes that looked very simple and mounted flush on the top of the triple clamp. I really don't want to cut any plastic. If the meter went bad or malfunctioned then I might be stuck with a hole in the fairing that nothing will fit. After reading about all of the electrical problems others have encountered, I'm pretty certain that I want a voltmeter. Let me see if I can find a picture.
I was just about to buy one until I read the customer comments and every one of them said it is not waterproof and not for outside use...
ZoomerABIjust noticed that AeroStitch has an interesting combo meter-> air temp, volt, batt condition etc. $32 Any one tried this gauge?
Detailed Images
I found the photo. The brand name appears to be C-Volt but a google search didn't turn up anyone selling them. This is exactly what I'm looking for. I could velcro it on and if it ceased working, off it could come and be replaced with another.
[image: gallery_15943_4295_8429.jpg]
Voltmeter I want
KPerhamI was just about to buy one until I read the customer comments and every one of them said it is not waterproof and not for outside use...
Detailed Images
Info galore in a compact, digital format that could fit nicely in your bikes' cockpit. Two thermometers incorporating an ice/freeze alert, a voltage meter, a three-LED battery condition meter, and a combination clock/stopwatch that operates in either 12 or 24 hour formats tells you a lot about your surroundings, the time, and the condition of your charging system. A 'black ice' alert flashes when that hazardous road condition threatens. Temperature minimums and maximums can be stored in memory and cleared easily. Not extreme weatherproof without custom modification (disassemble, apply silicone sealant, reassemble) 5.5"×1"×.75".
I had one on my Superhawk. Just had it tucked up under the windscreen and would put a plastic bag over it if I washed the bike. It worked well enough for the price and was still on the bike when I sold it after 4 years of being on there. For the VFR I went with the Datel and have no complaints. It is made much better and I never have to "remember" to cover it up. Since the VFR already has a clock and temp on it, the 5-function one was just duplicate crap that I didn't need.
wera803
Detailed Images
I'm looking for something for my Pacific Coast, ideally with a clock and back light. Since it sits outside for a day and a half at work, I definitely need a waterproof unit! Maybe I'll just have to forget the clock option... Can't believe Honda left a clock off this bike!
I was searching the internet last night looking at different voltmeters. I've been thinking of getting a small marine voltmeter (round, car-like one and not digital) and making a bracket that would fasten to the fuel tank bolts or something. I'm thinking that the needle would move a lot due to movement and vibration. The marine ones are waterproof and have vibration damping built in but on a bike....... Plus, it might look hideous. I wish they still made the one in the pic I posted.
bill220I was searching the internet last night looking at different voltmeters. I've been thinking of getting a small marine voltmeter (round, car-like one and not digital) and making a bracket that would fasten to the fuel tank bolts or something. I'm thinking that the needle would move a lot due to movement and vibration. The marine ones are waterproof and have vibration damping built in but on a bike....... Plus, it might look hideous. I wish they still made the one in the pic I posted.
Saw this recently on the Pacific Coast group:
Overtons.com. The Teleflex Vector 28236 for 24.99
There are a few on this page:
Analog Voltmeters
I guess it is waterproof as it is a marine type analog meter.
Also there was mention of a Honda Line Analog voltmeter for $50 plus shipping, but I've not seen that one or where to order. I guess check with your favorite dealer?
I just ordered a couple of the Datel units myself. I also found an Acura Integra digital dash clock on ebay that I'm hoping I can wire up into my Pacific Coast. Thought about an Infinity analog, but the logo would have bothered me on a Honda! :pissed:
i had a lascar and it WAS NOT water proof....it died in a HUGE storm that we had. liked it though and will probably get another one that IS water proof:
here is the one i bought that was only splash proof: http://www.lascarelectronics.com/pdf-usb-d...01208251476.pdf
http://www.lascarelectronics.com/usb-data-...p;submit=Search
edit: just ordered another emv1200....didnt see any water proofs that mounted easily. i'll try coating the back with silicon and see how that works.
turtlecreeki'll try coating the back with silicon and see how that works.
Also consider putting a piece of clear packing tape over the front of the display to seal it.
[image: gallery_10606_3386_27370.jpg]
voltmeter
[image: chargingstatusindicatorve9.jpg]
[image: chargingstatusindicatordr0.jpg]
[image: chargingstatusindicatorld2.jpg]
[image: chargingstatusindicatordw7.jpg][image: chargingstatusindicatorxd6.jpg]
Thanks for reading!
Tightwad
Update first post with the review
This farkel thing is really getting out of hand.
One is already taken, so only one remains. After that I will order and configure them on request, but there will be a slightly longer delay in shipping.
I realized if I had one of them with my voltmeter last spring, I wouldn't have been panicking when the volts shot up to 19 volts (meter wire came loose). HS and Dutch still laugh at me....
I was also wondering if anybody tried any of the voltmeters out of the aerostich catalog? I wanted to get one for my bike, and another for my boat.
dcompsonI was also wondering if anybody tried any of the voltmeters out of the aerostich catalog? I wanted to get one for my bike, and another for my boat.
Do you mean the Kisan "Charge Guard" meter? that one tells you just about everything there can be....Voltage, temperature, ice warnings, etc. Seems a bit pricey at $147, and somewhat big, but could be fun to have.
Tightwad I'm considering on getting one of the FPSI 1010-1 you found for my Gen4 Extra Dash Light project
http://www.vfrdiscussion.com/forum/index.p...c=47844&hl=
Please post or pm any more info that may help. The best price I found so far is $23 if you found a better price. Seems like you found a nice farkel.
I disagree atleast with a modern bike that monitors and adjusts, you can see anywhere from 13 volt idling with heavy electrical load , to 15volt, if a high charge rate is needed. The average I agree is in the 14.5 to 14.9v range in a normal state.
If you want to get technical you could have enough of a load that you are discharging. To me I look at charging voltage at operating speeds, not idle. If my operating voltage is not above 13.75ish I would be concerned....because when I am idling I know I will be in a discharge state. I have loaded mine enough with heated gear, grips, gps etc to get to this state.
My point is, if a light is constantly going off no matter the condition, its going to drive ya nuts, better to only come on if actually an issue. Like an oil light, very simple for those who want the idiot like, many will want the direct readout IMO.
End of thread · 51 posts recovered Wayback Machine snapshot 18 Sep 2021
