Bypassing The O2 Sensor On A 2001 Cbr600f4i
10 posts Started 20 Nov 2008 Last recovered post 20 Nov 2008 Wayback Machine snapshot 14 Apr 2015
Assuming that it is the same procedure for both models... How do you bypass the O2 sensor so that the "FI" light will be off? Unwittingly bought an exhaust for my F4i... found out later that there is a difference between California models and the rest. I remember reading somewhere that you just need a few resistors.... but I'm not sure which ones?
Thanks!!!
The same 330 ohm resistor mod should apply
Thanks Tightwad. Do you happen to have a link to the mod?
I take it you have a CA model F4i w/02, otherwise just plug the hole if not. I think there's only one 02 on your CA F4i. :cool:
Yes, the bike is a Cali model, the exhaust is not.
+1
+1
so, how many do I need 1... 2?
Which wires do I cross?
The resistor goes in the plug that comes off the wiring harness. You'll need 1 resistor per o2 sensor.
awesome! Thanks guys!!!!!!!!!
End of thread · 10 posts recovered Wayback Machine snapshot 14 Apr 2015
